Help! B Series; car shutting off
Old Apr 8, 2010 | 04:45 PM
decko's Avatar
Default Help! B Series; car shutting off
Recently I've noticed every once in a while my throttle will act up and either jump into high r's up and down or my car will die completely, it only happens when in gear... Also on the occasions it looks like its about to die, if I give it gas it will say it's at 2.5-3k rpm but the car is completely dead just coasting.. If I notice it happening then throw it in neutral wait a second and go back into gear it stops tweaking out for a little bit.. Motor is a b16a3 bottom end w/ a b16a2 head & p28 ecu.. I've been told it can be a tune problem, but wanted some second opinions before I go spend the $$
Old Apr 8, 2010 | 06:20 PM
decko's Avatar
Default Re: Help! B Series; car shutting off
Anyone?
Old Apr 8, 2010 | 07:02 PM
decko's Avatar
Might just get a retune and see if it helps.
Old Apr 8, 2010 | 07:13 PM
mooze's Avatar
this happened to me because of my icm in my dizzy once, then again when the screw holding the rotor in place came out. then again because if the icm.
Old Apr 8, 2010 | 07:19 PM
speedooo's Avatar
Sounds like a fueling issue...how old is the fuel pump?
Old Apr 8, 2010 | 07:31 PM
decko's Avatar
Not quite sure, I do know it was tuned kinda rich so it dumps a lot of fuel in general, especially when cold.
Old Apr 8, 2010 | 09:55 PM
decko's Avatar
Any way to check a fuel pump?
Old Apr 8, 2010 | 10:05 PM
mooze's Avatar
turn the key to on and listen to it prime.
Old Apr 8, 2010 | 10:13 PM
decko's Avatar
-.- I feel stupid, haha. It's not the fuel pump.
Old Apr 9, 2010 | 02:06 AM
decko's Avatar
123
Old Apr 9, 2010 | 02:23 AM
mooze's Avatar
if fuel pump primes every time i would bet on the dizzy
Old Apr 9, 2010 | 02:26 AM
decko's Avatar
Wouldn't a bad dizzy throw a CEL?
edit- does anyone agree that it could be caused by a poor tune?
Old Apr 9, 2010 | 03:09 AM
mooze's Avatar
not all the time actually it seems rare that it does indeed throw a cel. if it was in the tune it shuld be consistent not some random jump
Old Apr 9, 2010 | 10:23 AM
decko's Avatar
Makes sense, I'll check out the dizzy in a bit.
claud122003
Jun 11, 2010 04:28 PM
woodenchef
Apr 29, 2010 11:45 AM
xkwzt21
Jun 10, 2008 12:58 AM
`chrisb
Feb 26, 2008 03:33 PM
Beezle
Mar 31, 2005 10:45 AM
