95 civic no power to the fuel pump plz help!!
Old Apr 8, 2010 | 12:42 PM
greencivic_0789's Avatar
Icon3 95 civic no power to the fuel pump plz help!!
i own a 95 honda civic ex h22a. last monday i was driving down the road and my car started acting like it was running outta gas. it finally came to a stop and the car would not start. when i turn the key forward i dont hear the fuel pump kick on so i checked the fuses under the dash and under the hood. they are all good! so i checked the main relay and that is good too! so i figured it was the fuel pump so i bought a new walboro 255lph and threw it in. the car still has no power to the fuel pump. so im not sure what to look at now? the car isnt that old i wouldnt think my wiring is starting to go bad. and if it is wouldnt it pop fuses. any help here would be great! thanks.
Old Apr 8, 2010 | 12:49 PM
92lxsleeper's Avatar
Default Re: 95 civic no power to the fuel pump plz help!!
hit the wire at the pump with a multimeter to check voltage. if it doesnt have voltage, test at the main relay out part. if that has voltage then follow the wire and look for trouble spots
Old Sep 30, 2010 | 09:33 AM
ngrubb1415's Avatar
I have a 95 civic EX and I am having the same problem. I was also driving and the car acted like it wasn't getting any gas. I have since tried many things. I have tried a new fuel pum, fuel filter, three different main relays, two other ECU's and another key switch wiring harness. I have also tested the main relay and it appears to not getting power from the key switch and the ECU. If anyone knows what else i could try please let me know. Thanks
Old Sep 30, 2010 | 09:36 AM
Former User's Avatar
^Did you check whether hood fuse 31 or dash fuse 24 is blown?
Old Sep 30, 2010 | 09:43 AM
ngrubb1415's Avatar
Yes, I have. I have asked several people about this and no one has any other thoughts of what I should check. I don't have any other ideas of what to check for. I have two parts cars that i have taken parts and tried.
Old Sep 30, 2010 | 09:45 AM
ngrubb1415's Avatar
Thanks for the reply and i'll be sure to double check them again when I get home.
Old Sep 30, 2010 | 09:46 AM
Use a test light to check for voltage at both top tabs of installed fuses 31 and 24. Click Fuse link in my signature.
If both tabs have voltage, then next check whether the main relay plug gets voltage on both wires from those fuses.
Old Sep 30, 2010 | 09:49 AM
ngrubb1415's Avatar
OK i have not checked with a test light at those fuses but have checked the wires coming into the main relay. Thanks again i'll check that as soon as I get home.
Old Sep 30, 2010 | 09:53 AM
Test fuse 24 with the key in ON(II).
Testing fuse 31 can be done with the key in the OFF position.
The corresponding wires for fuses 24 and 31 to test for voltage in the main relay plug are Blk/Yel and Yel/Wht, respectively.
Old Apr 21, 2015 | 03:08 PM
jg93EX's Avatar
Hate to dig up an old thread.I have a 93 ex that shut off after a trip to the store.I checked the main relay it's good but no power to the pump.So I checked fuse 31 and 24 both good.So checked for power at main relay.I have power on 31 yel/wht but no power with key on on fuse 24 blk/yel.So what do I check now?
Old Apr 21, 2015 | 03:35 PM
jg93EX's Avatar
Here is the wiring diagram that might help others.
Old Apr 22, 2015 | 12:14 PM
delsolintegra's Avatar
This is an old thread but it's possibly the ECU. The capacitor on the ECU circuit board for the fuel pump priming circuit will deteriorate and give an intermittent problem for fuel pump priming. Borrow a known good ECU and try that.
dcrppf
29
Sep 26, 2020 04:27 PM
Whiteonblackej
82
Mar 19, 2015 12:55 PM
ssdjoey1904
Aug 6, 2014 04:48 AM
CreateAaron
Jun 23, 2014 08:32 PM
greencivic_0789
Apr 8, 2010 03:26 PM
