Hondata boost solenoid question
Old Apr 8, 2010 | 02:22 AM
ochocinco's Avatar
Default Hondata boost solenoid question
Never really asked my tuner about this question i had. How exactly do i change my boost up or down? Is it just as simple as plugin in cable and bringing up Smanger on laptop and its a setting i go to and im done or even can look at how it is set to now?
Also with boost by gear can i just change it from say 8psi to 9 by simple click? Changing the boost by gear will not effect my tune will it as long as i dont go above psi tuned on?
Old Apr 8, 2010 | 06:38 AM
Top Ramen's Avatar
Default Re: Hondata boost solenoid question
I use Neptune, but I believe Hondata is similar - launch the program, make the changes to the boost settings and upload the new map. Should be all you need to do if it was tuned to the highest boost level you are using.
Old Apr 8, 2010 | 07:29 AM
inspector01's Avatar
Yeah, just go into Smanager, parameters, boost control, and you can change either the desired boost or set a duty cycle, it depends on how it is set up. You will be fine as long as you keep it at or below the highest boost level it was tuned for.
Old Apr 8, 2010 | 12:44 PM
ochocinco's Avatar
Thanks guys got it figured out.
WAUKEENEM1
Engine Management and Tuning
Apr 5, 2013 07:54 PM
rfelix89
Sep 7, 2012 06:59 AM
JusT a Cx
Feb 24, 2004 05:58 PM
Ek00fbp
Oct 8, 2003 10:08 PM
5thgencivic
Sep 17, 2003 06:41 PM
