Clutch burn
Hey guys, recently purchased my s2000 2 days ago and it drove fine until
i came off the highway near my house and started to smell something burning. I later found out it was my clutch when i pulled into my garage.
There was no visable smoke, just smelt horrible inside the car. The car shifts normally, but is it normal for the clutch to push in all the way to change gears? i bought the vehicle like this (thats how i drive) but i accidently 1 time didnt push in the pedal all the way maybe half and it didnt dis-engage
Is this a big problem as far as the clutch burn or just a minor scar that could later be driven out later driving normally?
Thankyou
-Kevin.
Thankyou
-Kevin.
That's a hard call to make since we, nor you know the previous state of the clutch. If the clutch is/was in proper order you should be fine. I wouldn't go all the way down, but I don't know if it actually harms the clutch or not
Here is a thread that could have the info to your problem check it out.
https://honda-tech.com/forums/honda-s2000-5/hello-everyone-2731215/
question numba 1 do u know how to drive?
"but is it normal for the clutch to push in all the way to change gears?"
i was under the impression that to disengage a clutch properly u had to push the clutch peddle all the way down, call me crazy but thats how i do it
yes i know how to drive, all vehicle ares different, i read that others push down there clutch in half way and change gears. i dont do that but thats what i read.
If you didn't push the clutch pedal far enough you probably would have heard a god awful grinding noise. You technically only need to push the pedal far enough for the pressure plate to separate far enough from the fly wheel for the clutch disk to spin freely but you should always push the pedal to the floor to be sure. How many miles are on the car? You might just have an old worn clutch in need of replacement, but for you to smell clutch it would have to be slipping. Did you ever notice your revs increasing but not your speed while in gear and clutch out?
not necessarily dude. i've driven cars with a real high biting point and i never fully depressed the pedal. faster changes too.
If the smell is gone, and it isn't slipping it was probably just a minor boo boo. I dunno how the years clutches are different, but my clutch disengages at about 1/4th the way down. sounds like if anything you barely disengaged it, it rubbed thus the smell. If it's not slipping within a few days you probably did very minimal harm.
you weren't disengaging enough on that day you burnt the clutch. I think you rested your foot on the clutch and let it sit. if that sounds about right, you have nothing to worry about.
Thankyou
-Kevin.
Thankyou
-Kevin.
if you were dropping gears on the highway, this will lead to a massive exertion on your clutch disk. you probably scorched it a good bit
I said there wasn't any smoke to be seen during and when i parked the car, i was downshifting cause of a redlight on the highway. (you could be thinking a redlight on a highway, yes kansas has some LAME *** intersections on the highway)
Anyhow smell is gone and its been about 4 days i believe since the incident
jdmstyleEJ6
12
May 9, 2010 04:13 PM
