smoking.
Old Apr 7, 2010 | 10:42 AM
1904wrencher's Avatar
Default smoking.
Ok, I start my car and when i back up, there is a black coat on the ground. I believe the timing is off.
the motor is d15b2
239,plus thousand miles and still running
Please help me with some info, Thank you.
Old Apr 7, 2010 | 11:06 AM
4drEF's Avatar
Keyboard Humorist
Default Re: smoking.
Set your timing.
Also check compression.
Your motor is only and it would be no surprise if the rings and cylinders were starting to
wear.
Could also be valves.
Any tune ups lately?
Ever do anything like injector and valve cleaner?
Old Apr 7, 2010 | 01:37 PM
No. I did an oil change and valve cover gasket about 200+ miles ago.
thanks
anymore advice.
shocker911
10
May 10, 2013 10:51 PM
93lsDA
Apr 13, 2010 12:34 PM
young geezer
May 21, 2009 08:37 AM
ultradx
Mar 26, 2007 10:17 PM
frog1623
Feb 1, 2004 08:11 PM
