HELP - 1990 Honda Shut off while driving
Old Apr 7, 2010 | 07:45 AM
hamelc1's Avatar
Default HELP - 1990 Honda Shut off while driving
I'll give you the whole story as I am at a complete loss. I have a 1990 Honda Accord. Yesterday, when I went to leave work I tried to start the car and it would turn over but wouldn't start. After several tries I finally got it to start, and drove home with no problems. This morning, went to leave for work, same thing happened. Car would turn over but was having a hard time starting up, but it eventually started after a few tries.
After driving about ten - fifteen miles on the highway I got off on my exit, turned at the next light and the car just shut off. Tried to start it again, and it will turn over, but won't start.
This didn't happen until we started to get hit with heavy rain. Not sure if that has anything to do with it. Any suggestions as to what it could be?
Old Apr 7, 2010 | 07:52 AM
TheMuffinMan's Avatar
He knows where you live!
Default Re: HELP - 1990 Honda Shut off while driving
Did all the lights come on when it shut off? Or did it act like the key was moved to the Off position? Or was it just the motor and all electrical items still functioned? Like your lights.
Any CEL?
I had similar issues (acted though like the key was turned to off) and it was the electrical portion of the ignition switch. I had replaced the alternator (possibility for you) already and had no change in behavior.
Old Apr 7, 2010 | 07:57 AM
hamelc1's Avatar
All the dash lights came on, wipers still worked, heater etc. So it was just the motor.
Old Apr 7, 2010 | 07:10 PM
90CoupeTX's Avatar
This sounds exactly like what just happened to me. As another member here suggested, it was the ignitor. I changed it out, and changed the cap and rotor at the same time, as the rotor had been hot as hell and was brittle. Haven't had problem since. knock on wood.
Old Apr 7, 2010 | 07:32 PM
quickster's Avatar
test the parts in your distributor with a multimeter, digitals are better than analog btw.
Old Apr 8, 2010 | 06:20 PM
uberEFtuner's Avatar
Buy a new distributor with a lifetime warranty and you will be set.
Old Apr 9, 2010 | 05:46 AM
teggycb7's Avatar
if it happen to you agian you might wanna check your main relay ,some times when it get hot it acts like that ...i had that same problem, and it was just my main relay
Old Apr 10, 2010 | 04:43 AM
HondaPartsHero's Avatar
Technical Hero
http://techauto.tripod.com/
DC5DC2
Dec 27, 2012 08:00 PM
vetalk90
Jun 27, 2012 04:22 PM
CanadianEh48
Aug 23, 2008 04:14 PM
bpetruzzo
15
Apr 21, 2004 04:42 AM
TurboedGSR
Sep 18, 2002 05:23 PM
