I TURN RIGHT AND MY CAR GOES NUTZ!!
Hey guys here I am asking another electrical question lol. Well I was drivin my girl home and everytime I turn right around a corner my car bucks and then when I turned into my driveway with the blinker on it started blinking fast as if there was a blown bulb then I straightened it out and it started blinking normal again it was really weird. Also my driver side axle I think the bearings are shot on the tranny side of the axle cuz I can feel it vibrating a little and it clicks every once and a while just thought I would throw that in. Don't know what that would cause a problem but hey it's a Honda anything can happen. So any Info would help also it can be a ground issue cuz I fixed that already.
thanks in advance guys.
Ok can I get some help here it's def not the axle and my car only bucks/studders when I turn right but only when I have the headlights on
Well it sounds like a ground issue, but if you're 100% sure that you fixed every ground in the whole car, then who knows what it might be.
Try and trace back from recent modifications that you've performed, and try and pin point when the problem started. If you can link the point to when it started to a certain modification, then check your work again.
This is my guess. Make sure your battery is secured and that it's not touching the hood. Sometimes an improperly installed aftermarket air intake can rub on the positive terminal and lead to shorting.
i just put a towel over my battery for now until i put it in the trunk but that is what i was afraid of (shorting out)
Well I have a side post battery and stock intake but no worries guys I sold the car now I have another post check it out I need some help. It's titles. SPARK+GAS=NOT RUNNING
aser1z
Apr 7, 2007 04:29 PM
