91 crx si wire tuck
does any one have a how to on a wire tuck? im hoping it will be for a crx si with the stock d16a6 but i guess any ef bay would help. i DO want to keep ac, i live in texas and its really hot in the summer.
well theres different kinds of tucks easiest ive heared of is just extend all the wires and hide them behind the intake manifold and all up front wireing will go in your fender ive considered doing it on my y7 in my ef just havent cared enough to do it good luck i know i didnt help much
check the FAQ's because there is the information in there, If you do a wire tuck, do it right and solder and shrink wrap EVERY wire you ever cut. This will save you and any future owners sooooo many headaches once it is all done. Dont hide your fuse box someplace you cant easily access it, because after all, fuses take a dump once in a while.
http://www.crxmpg.com/diy-honda-crx-wire-tuck/
that should answer all your questions and end this thread.
i have a si, and ive also heard if you put all the wires behind the blinker its hard to put the blinker back in. thats why i can here hoping some one had a write up for a crx si
you don't "have" to delete your ac basically ive down a couple before on different cars but on my friends ek we extended most of the wires and ran everything down below the manifold... basically just take your time with it not hard just takes time
i found this place this guy does a full wire tuck on a crx
http://importsnc.com/forums/car-tech...-150-pics.html
racingant
May 29, 2004 10:06 PM
