Fluctuating Idle after turbo install
Old Apr 6, 2010 | 04:45 PM
alacard's Avatar
Default Fluctuating Idle after turbo install
The engine is a GSR with a turbo setup including a bov, tial wastegate, turboxs manual boost controller, etc. About 60% of the time the car is idling, it fluctuates. I checked all of the turbo-related vacuum lines and couldn't find any problems. They are all tight and zip tied. So I am starting to think it is a problem with the engine itself because, prior to the turbo, every once in a great great while the idle would fluctuate. Also, I am still on the basemap, I will be tuning next monday...is it possible that the tune will fix the problem?
Old Apr 6, 2010 | 04:50 PM
cleansi's Avatar
Default Re: Fluctuating Idle after turbo install
hello no tune taaaadaaa. phhhhh......
whats your wideband showing?
whats you set up fuel management ecu ect?
wow 3k post and a senoir here first fi build? not trying to be a d@ck
post in the FI forum
Old Apr 6, 2010 | 05:29 PM
alacard's Avatar
A tune is just the magical answer? I find that hard to believe.
No wideband. I'm on a crome basemap which will be tuned Monday.
Not my first forced induction build.
And as I stated, this seemed to be not related to the turbo install anymore...so, therefore, the question being placed in the 92-00 civic forum would be perfectly appropriate. Now that I am turboed, I need to post every tech question in the forced induction thread? No.
Old Apr 6, 2010 | 05:37 PM
cleansi's Avatar
well considering most of the thread consist of a problem with forced induction i would post there just trying to help
why i think its your tune is becuase the basemap is a guess/estimate of what you a/f should be ,
whats your set up?
are you throwing any codes?
Old Apr 6, 2010 | 05:53 PM
azandford's Avatar
have you checked the basic idle problem causers? iacv or fitv ( if you have it )
simplsi
Nov 22, 2007 12:33 PM
lkailburn
Jul 27, 2005 10:36 AM
aalb1
Sep 19, 2004 02:14 PM
Boosted Gsr Hatch
Feb 20, 2003 11:51 AM
turbogsr
Dec 1, 2001 08:05 AM
