Converting Automatic SOHC ECU to 5speed?
Old Apr 5, 2010 | 07:23 PM
tacosandbeans's Avatar
Default Converting Automatic SOHC ECU to 5speed?
Hello i have a 1996 automatic d16 SOHC Ecu and I'm using it on my 1996 d15 5speed SOHC swap. I heard there's a way to reprogram the automatic ECU for Manual applications. Can anyone point me in the right direction?
Old Apr 5, 2010 | 11:46 PM
Linked's Avatar
Default Re: Converting Automatic SOHC ECU to 5speed?
p28???
the way i did mine was I THINK cut resister RP18
and jump RP17 or it might have been the other way around
Old Apr 6, 2010 | 03:26 AM
hondamark35's Avatar
what linked said is right but only if it's an OBD-I ECU. a 1996 should be OBD-II so unless you already have converted to OBD-I... you'll need to.
Old Apr 6, 2010 | 09:03 AM
94EG8's Avatar
Seagull Management
You can't convert OBD2 ECUs unfortuntely.
Old Apr 6, 2010 | 05:37 PM
****...so will it still run okay ?
Old Apr 6, 2010 | 05:42 PM
D16SiHatch's Avatar
it will run but you will throw a code in relation to the auto tranny no longer being there
Old Apr 6, 2010 | 06:08 PM
Will it idle unusual?...
Old Apr 7, 2010 | 09:05 AM
D16SiHatch's Avatar
not sure on that as i've never done this personally. somebody will chime in eventually i'm sure
Old Apr 8, 2010 | 02:41 PM
Linked's Avatar
idk how it'll perform, but i know with certain CELs, vtec wont engage
Old Apr 8, 2010 | 03:02 PM
thumper64's Avatar
OBD2 ECUs, no, you can't. Well, you can chip them, but it's hard and nobody does it.
Just get a 5 speed EDU. Or better yet, get an OBD1 ECU and you can do whatever you like with it.
j.packsb
Engine Management and Tuning
Oct 30, 2009 09:47 AM
j.packsb
Oct 29, 2009 07:16 PM
Rahxephon
Aug 31, 2006 02:13 AM
tiresmoke
Feb 24, 2004 04:20 AM
crxcess
Sep 14, 2003 08:53 PM
