EJ1 rear Disk Conversion Questions
Hello ,
i want to make the rear disc conversion on my EJ1.
I have the rear trailing arms from an Civic Vti. The seller gaved me 2 trailing arms , a sway bar , brake booster , 13/16 master cylinder and 30/30 prop valve.
On my car, 1993 Civic Ex , i have installed a 7/8 master cylinder and a 30/30 prop valve. On front , i have 10.3" rotors , stock calipers.
1. I want to ask u guys , which master cylinder i should use now, 7/8 or 15/16?? Which one is the best for my setup?
2. I need the 40/40 prop valve , or i can use my 30/30 ?
3. And , is there a difference betwen my stock brake booster and the VTi ones?
Thank u very much and hope to get ur answer soon , so i will be able to start the conversion.
LE : I already purchased a 4040 pv from ebay and trailing arms bushings
use the 15/16's or 1" from an itr, 15/16's works best
40/40 prop valve
i don't know what size the VTi is, but bigger is usually better. I upgraded to a bigger one when i did mine.
there's more info about EJ1's on ej1oc.com if your interested. Forum dedicated to EJ1/2's
40/40 prop valve
skill178
16
Oct 9, 2011 04:38 PM
Comenzi SUA
11
Apr 7, 2010 03:32 PM
AThiker
22
Feb 27, 2005 05:14 PM
