Ticking skunk2 valvetrain. please help
A while ago I did a 4th gear pull on the highway. After the pull I noticed a ticking in my head area. My oil level was kind of low the following morning when I checked after noticing the ticking. I have pro 1 cams, pro springs, retainers, and valves. Fresh head build. Car is tuned with Neptune eprom. Recently ajusted valves to .006 in and .007 ex and the ticking is still there. It sounds like it's just in either the 1 or 2 cylinder but i could be wrong.It doesn't get any quieter after the car gets warmer. Not sure what a piston and valve hitting sounds like, but it does sound like something may be touching. If that makes sense. Cams I beleive were set to 0 before the tune. Camn anyone offer any helpful suggestions to what the prob may be. thanks
thanks for the uggestions. I'll check them in order of easiness. Someone also mentioned to check valve lash, so I'll check all those out until I find the problem. I forgot to mention that I have the Bosch 1000's. Someone said they could tick pretty loud.
I would assume it would be a bent valve, specially since it happen after a pull. I'd adjust the valve lash, and see if that fixes it, if not do a leak down and go from there.
MY FRIENDS B SERIES WITH PRO 1 AND MATCHING SPRINGS SOUNDED LIKE A DIESEL FROM THE VALVE TRAIN, FOUND OUT TWO INNER SPRINGS BROKE. HE GOT LUCKY NOTHING DROPPED
mjfubar101
14
Jun 30, 2007 08:29 PM
killerpenguin21
Nov 21, 2006 09:26 AM
