91 CRX RACING HARNESS BAR
Bought one not sure how to install or where to? it has door mounted seatbelts which would also mean theres no screwable body parts where the normal harness bar would go. any input or pictures or a install diagram would be awesome point me in the right direction fella's.
umm take off side pillar panel you should notice a hole well on mine there is one but if you have one then all you would have to do is weld a nut in place if not make a hole weld a plate with a nut and bam just screw the bar in to dat simple as pie oh yea the bottom by the doors should have holes with nuts already weld for 88-89 seat belt conversion if not just get a plate weld nut to and screw into that oh and heres a thread if you dont get it just do the same but not for seat belts
http://hondaswap.com/civic-crx-ef/do...-435732/2.html
streetsold6teeny8
30
Aug 29, 2009 02:49 PM
Unique Artwerkz
Jan 23, 2008 03:27 PM
