need some help
Old Apr 3, 2010 | 09:23 AM
loandslo's Avatar
Default need some help
got in my car to leave work this morning it ran fine last night and every day before now. anyway i pulled up to a stoplight and my speedo freaked out and started bouncing between 0-20 and then from 40-60- then from 40-100. and then just random bouncing the rest of the way home.
the check engine light came on at the exact moment the speedo freaked out, i took it to autozone and he pulled the codes. the code was p1298 electric load detector circuit high input probable cause.
open or short circuit condition.
failed ecm
i dont really get what the problem is? is the speedo and the light connected cuz it happened at literally the exact same time.
you guys got any ideas?
i checked the number 15 fuse with a circuit tester since these are all common problems of the number 15 blowing and the fuse is fine. thanks in advance
Old Apr 3, 2010 | 05:10 PM
loandslo's Avatar
Default Re: need some help
bump neone
Old Apr 4, 2010 | 05:02 AM
tonyhatchetman's Avatar
Check or replace the alt,.... Good luck
Old Apr 4, 2010 | 05:17 AM
loandslo's Avatar
i was thinking the same thing but would the alternator make my lights constantly flicker and my speedo wack out? its worth a shot though
Old Apr 4, 2010 | 06:31 AM
Ya mine did that exact same thing ...it was the regulater inside the alt.....good luck
Old Apr 4, 2010 | 06:43 AM
loandslo's Avatar
mmk got it tested alternator is peachy
Old Apr 4, 2010 | 07:03 AM
D Griff's Avatar
Make sure to test the amperage on the alternator and not just the voltage. When mine was bad the voltage was still perfect but it was putting out about 1.5 amperes instead of the specified 50.
Old Apr 4, 2010 | 07:04 AM
D Griff's Avatar
I don't really know what shows with a bad regulator though.
Old Apr 4, 2010 | 06:01 PM
loandslo's Avatar
the alt testeted in the morning cuz now my car isnt getting power so im thinking its deff the alternator thanks for the input guys
Old Apr 4, 2010 | 06:08 PM
start the car and unhook the battery cable and if it dies or the lights start flashing worse it it the alt.......good luck
Melblue
Feb 18, 2016 02:49 PM
Cdeese910
Oct 25, 2012 07:56 AM
ej6kevin515
Jan 18, 2012 04:47 PM
J.HA
10
Mar 27, 2011 09:00 PM
liquidscor00
Jun 24, 2005 11:56 AM
