Rear tires wearing on the insides????
Old Apr 3, 2010 | 07:40 AM
craiger28's Avatar
Default Rear tires wearing on the insides????
98 Civic LX 4 door, the rear tires are wearing on the insides of the tires. We have looked at all the suspension pieces and none are bent and the bushings are good and not wore out. Let me know what part or parts you will need to get to fix this problem. I am tired of replacing tires.
Old Apr 3, 2010 | 07:43 AM
darkenedsol's Avatar
Default Re: Rear tires wearing on the insides????
When was the last time your car was aligned?
Old Apr 3, 2010 | 08:41 AM
CleanazzEJ1's Avatar
Is your car lowered? If so, get a camber kit!
Old Apr 3, 2010 | 09:57 AM
craiger28's Avatar
Recently aligned, no it is not lowered.
Old Apr 3, 2010 | 10:00 AM
VTECROAR96typeR's Avatar
dont listen to this guy! camber kits are useless. are the top of the tires facing towards the car alot ex: / \ .
Old Apr 3, 2010 | 10:05 AM
craiger28's Avatar
Yes, exactly...
Old Apr 3, 2010 | 10:08 AM
its really strange for your car to have alot of negative camber with out your car been lowerd. How long ago did you get the alignment?
Old Apr 3, 2010 | 10:16 AM
craiger28's Avatar
Within two months. I replaced the original rear upper control arms that were still good with a set of aftermarket ones that you can adjust. My alignment guy that I trust very much has had this problem with these year civics before and he stated this is what is needed to fix this problem. They were $115.00 for the set.
Old Apr 3, 2010 | 10:36 AM
RagnarX's Avatar
sounds like toe is out
Old Apr 3, 2010 | 10:39 AM
batallic's Avatar
did yur buddy align it in a shop with the proper machine
Old Apr 3, 2010 | 11:01 AM
BiG ChOr!Zo's Avatar
my 96 ej8 sedan wears out tires from the inside rear also and its complete stock oem height...i think this is a common problem with this generation and it would be a good idea for you to try the washer trick...!!!
Old Apr 3, 2010 | 11:07 AM
yeah but when someone does a alognment they adjust the toe, camber and , cast
Old Apr 3, 2010 | 01:47 PM
popejooie's Avatar
these hondas only have adjustable toe from the shop.
Old Apr 4, 2010 | 07:33 AM
epic.fail's Avatar
deffinatly toe..i have my rear tires at almost -7 degress camber and dont get abnormal wear
Old Apr 4, 2010 | 10:35 AM
batallic's Avatar
yeah but caster is only on the front and caster doesnt damage tires, and u cant adjust camber
Old Apr 4, 2010 | 10:41 AM
98civdx's Avatar
Master Detailer
take it in and have the 0 out toe front a rear.....
Old Apr 4, 2010 | 12:37 PM
Pothole987's Avatar
biggest problem is when people drive up over curbs. it pulls the alignment arm out a litttle each time
cilvia
Mar 23, 2011 05:28 PM
tonyhatchetman
17
May 21, 2010 10:22 PM
andrewchopstick
Apr 7, 2010 06:15 PM
jordancrockett
Dec 7, 2008 12:54 AM
crxsir07
Suspension & Brakes
Aug 10, 2007 06:49 PM
