del sol smoking
Old Apr 2, 2010 | 11:21 PM
youryanyou's Avatar
Default del sol smoking
delete
Old Apr 3, 2010 | 12:21 AM
95soul's Avatar
Default Re: del sol smoking
Could be bad valve seals. Or it could be bad seals in the turbo. More likey the latter. How many miles on motor?
Old Apr 3, 2010 | 12:29 AM
System Lord's Avatar
Inspect the oil return line are you running a restrictor?
Old Apr 3, 2010 | 12:46 AM
95soul's Avatar
^Yep, that will cause oil to get blown past the seals, resulting in a cloud of smoke.
Old Apr 3, 2010 | 10:15 AM
youryanyou's Avatar
ill check my return line and whats a restrictor?
Old Apr 3, 2010 | 11:38 AM
youryanyou's Avatar
ok update.i took off my charge pipe that connectgs to the turbo itself and theres is a good amount of oil inside the pipe and inside the turbo.i notice wen i hit boost the car would smoke and keeps smoking.but if i were to just start it up and drive normal rarely any smoke.doesn this mean my turbo would need a rebuild?
Old Apr 3, 2010 | 11:44 AM
Si-Rhc's Avatar
If its a new turbo id like to say no, could it be oil hitting your turbo mani? Or coolent hitting something hot?
Old Apr 3, 2010 | 04:31 PM
http://www.cimotorsports.net/motor-s...r-fitting.html
Old Apr 3, 2010 | 09:42 PM
youryanyou's Avatar
yeah i had a restrictor.found out it was my turbo needs a rebuild.
93 Eg Couper
May 2, 2011 02:21 PM
1FastLS
Mar 31, 2006 04:33 PM
sir2sol
Sep 17, 2004 02:19 PM
S2KP
Dec 25, 2003 10:52 AM
blackdelsolsi
Jul 31, 2003 12:12 AM
