GSR Swap in a 98 DX EK Hatch.
The car is a 98 DX Civic Hatchback. It's going to be swapped with a GSR either obd2 or obd1 soon. Now, can I keep my stock harness that plugs out from the ECU through the firewall, or do I have to remove that and swap it out with an EX harness ? I remember doing a swap in a DX body OBD1 EG, and I didn't have to swap out the harness all I did was run the wires for the vtec and the knock sensor. now I heard GSR has the manifold where it uses a dual butterfly control as well, what kinds of adjustments need to be done to that. I heard people saying you need to run a couple of wires from the ECU towards that "targeted area", where there is a sensor located or whatever .. I have no idea... Should I also run a EX(p2p) vtec computer or a p72. Wouldn't it make more sense to run a p72 since you need it for the Dual Butterfly control ?
I think you would be better off gettin the GSR wire harness I know that the GSR engines are different then the B16's and B18C type R's and I know you can use the Type R wire harness on the B16 but you cant use the GSR because its different but I think you would be better off gettin the GSR harness that way it would be complete without riggin anything
you can either use the stock civic harness, and run separate wires for vtec, or use a 96-98 civic EX harness, where vtec is already "included" in the harness.
an integra harness won't "work" w/o extensive modification
I see.. as far as power difference. Is there anything different then when using the GSR harness compared to the DX/EX harness ? And what about the dual butterflies on the gsr manifold ? Do those need to be wired up to the p72 computer as well ?
Dont use a integra harness like stated above already^
use your stock civic harness its not hard to convert
go buy a solder gun and have fun, shrink wrap too
Dual butter flys were confusing so i never messed
with it, I had planned to change to a sk2, or edelbrok anyways
Now i use Skunk 2
P72 will work fine
as far as the harness conversion goes its a color match to the d-series
(except distributor) and you will need some plugs off the integra harness
Now i use Skunk 2
P72 will work fine
Dx 96-98 engine harness is made for a non vtec sohc motor
Ex 96-98 engine harness is made for a vtec sohc or dohc motor
The gsr manifold is very simple, just run a wire straight to the ecu from the IAB sensor plug. You need a gsr or h22 ecu in order for the IAB from the gsr manifold to work. IAB aka "dual butterflies"
please dont post when you dont have a clue what your talking about..
Agreed
Gsr harness wont work period. It will only work on 92-95 civics because they are typically similar. A gsr harness is only useful if your using it for scrap parts like sensor plugs. JDM or USDM will do
Agreed
VargasCTR98
Mar 28, 2007 02:34 PM
