OBD 1 DIZZY DIFFERENT HOUSING STYLES?
Old Apr 2, 2010 | 05:33 PM
DUKE LADUKE's Avatar
Default OBD 1 DIZZY DIFFERENT HOUSING STYLES?
So I just bought a 92-95 obd1 dizzy and its not bolting up to my Y8. I need the 2 plug design like it has but the housing is different . What Dizzy do I need for the right housing ?. I could only get one hole to match up with the wrong dizzy !... Need this ASAP!!!
Old Apr 2, 2010 | 06:34 PM
98civdx's Avatar
Master Detailer
Default Re: OBD 1 DIZZY DIFFERENT HOUSING STYLES?
not sure on the dizzy question but i think someone makes a harness so you are able to use obd2 dizzy on obd1 harness. just my 0.2 but i think that would be way easier.
EDIT- probullay not the best place to buy but this is what i mean
http://passwordjdm.com/PasswordJDM-D...P1881C320.aspx
Old Apr 2, 2010 | 08:49 PM
no
Old Apr 3, 2010 | 08:22 AM
CivicSpoon's Avatar
You need one from a DX/LX or CX; non-vtec. Or if you have the Y8 distributor too, you could swap the guts from the new one into the old housing.
Old Apr 4, 2010 | 03:37 PM
The housing was from a 2000 civic si , but the internals of it were from a '92
Old Apr 4, 2010 | 04:58 PM
BryanM.'s Avatar
Resident Gearhead
Pretty sure a B series dist. won't fit on a D series head.
Old Apr 4, 2010 | 05:01 PM
HondaPartsHero's Avatar
Technical Hero
any obd1/2 d-series will bolt right up with exception of D16Z6, D15B(VTEC), and D15Z1
Old Apr 8, 2010 | 05:31 AM
It was from a d series ...
Old Apr 8, 2010 | 06:11 AM
dpetro1's Avatar
c'mon man you were already told which dizzy to get in your other thread. you need a d15b7 or d15b8 dizzy. they can be found in the 92-95 civic cx/dx/lx or 93-95 del sol s
why would you go buy a 2000 civic si dizzy? regardless of the internals, the mounting flange is wrong as you have found out.
PS - 2000 Si is a b-series so im not sure why you are saying it was from a d
Old Apr 9, 2010 | 04:24 PM
BryanM.'s Avatar
Resident Gearhead
The B series housing won't fit a D searis head. Sorry, that's what I meant.
melissashelton1
Dec 21, 2009 12:28 PM
Ocnaj
14
Jun 30, 2008 06:11 AM
JDM_EK_JOE
May 2, 2006 08:47 PM
richboi
11
Apr 17, 2006 04:36 PM
IDriveHonda
Jul 8, 2003 07:03 PM
