harness identification??
Old Apr 2, 2010 | 12:39 PM
94_ls's Avatar
Default harness identification??
i recently picked this harness up the other day with my b16a swap, came out of and eg and is obviously obd1, wondering if any one can help me find out wat this harness came off off originally. it has a plug in the middle of the harness, which has 3 wires, im thinking egr. And not sure if this was originally wired for vtec. but any help would be greatly appreciated. thanks in advance
Old Apr 2, 2010 | 01:43 PM
itsnotfast's Avatar
Default Re: harness identification??
The 3 wire plug could be the speed sensor. It could also be a crank position sensor (maybe).
Old Apr 3, 2010 | 06:28 AM
94_ls's Avatar
ya i was thinkin vss also but it is in the middle of the harness and a little far from the tranny.
Old Apr 3, 2010 | 11:53 AM
itsnotfast's Avatar
It looks like its just below the plugs for the side of the head.
Old Apr 3, 2010 | 02:08 PM
94_ls's Avatar
ya not sure man. this harness is stumping me.
Old Apr 3, 2010 | 02:22 PM
mattliston's Avatar
could it be an auto tranny harness that has been modified? the lockout solenoid sits right under the distributor and could very well be 3 pin.
sorry I cant help much further
Old Apr 3, 2010 | 09:03 PM
94_ls's Avatar
does anyone know the color wires of a vss or egr?
Old Apr 3, 2010 | 10:06 PM
twotonecivic's Avatar
seems like a good logical thought
Old Apr 3, 2010 | 10:15 PM
mattliston's Avatar
wire colors? google ff tech, something like that. ecu wire colors run to the sensor.
compare the colors to the ecu pinout diagrams.
Old Apr 4, 2010 | 07:51 AM
94_ls's Avatar
arent the ecu wire colors change when they go into the engine harness? ill plug it in and see if i can nfigure it out. thanks for info
Old Apr 19, 2010 | 02:15 PM
94_ls's Avatar
found out someone had spliced in a vss with different wire colors. thnks for th help. its a d16 harness.
Asmooh
Apr 23, 2014 04:32 PM
nello a.
Dec 24, 2008 12:20 AM
hb90racer
Feb 1, 2005 08:59 PM
