Cel...code 19 help
Old Apr 2, 2010 | 02:48 AM
turbodelsolb16a2's Avatar
Default Cel...code 19 help
So I have recently put togther a b18c1 in my eg2...and my check engine light came on and it was code 19..14...6...I fixed the other to but 19 is for the automatic tranny lock valve or something like that..can somebody explain what this I have the gsr 5 SPd tranny..
Old Apr 2, 2010 | 03:09 AM
accord2civic2prelude's Avatar
Default Re: Cel...code 19 help
what ecu are you using? is it for manual or auto?
Old Apr 2, 2010 | 03:16 AM
I have 2 ecu I tried the soposely jdm p70 that's the one were I got the codes...then I tried a p13 ecu no cel but it would idle...
Old Apr 2, 2010 | 03:37 AM
the p70 is from a zc right? that is your problem. why would you run a sohc ecu on a dohc unless its been modified with the correct base map atleast.
the p13 idles rough? try getting a pr3 or p72 basemap loaded or just find a p72.
Old Apr 2, 2010 | 03:41 AM
Yea I figured oh boy I got the p70 told me it was jdm?? Idk I've never heard or p70...it just drops an goes up n Dan back down...
Old Apr 2, 2010 | 03:45 AM
yeah get your money back unless you want to get a basemap for it. otherwise with the p13 the idle goes up the down, and back up and back down..over and over? if so, try cleaning your iacv..
t3mppa_FIN
Engine Management and Tuning
Oct 20, 2012 06:07 AM
bukhumlae
Dec 1, 2009 09:08 PM
InvaderTrax
Apr 3, 2009 11:33 AM
sloaccord
Dec 21, 2001 07:42 AM
