steering wheel hub which is best
Old Apr 1, 2010 | 09:38 PM
si90rex's Avatar
Default steering wheel hub which is best
i have a cheap one that was in the car when i bought it but it had a personal steering wheel with it. but the hub is cheaply made....the horn doesn't work and its has a coragate plastic piece that wont stay in the right spot.
i want to buy a new hub. and i want a good one.
NRG short
NRG thin
MOMO
Works
and whatever else is out there.
Thanks
Old Apr 1, 2010 | 09:43 PM
RagnarX's Avatar
Default Re: steering wheel hub which is best
I suggest the NRG short/thin. I had the NRG short hub/quick release in my car for almost 3 years, never had an issue. great quality imo, definitely not cheaply made.
Old Apr 2, 2010 | 12:30 AM
Smash03's Avatar
If you're gonna get a quick release along with the hub, I recommend getting the NRG thin hub like Ragnar said. The quick release will place the steering wheel closer to you so the thin hub will bring it back down a lil.
Old Apr 6, 2010 | 09:48 AM
si90rex's Avatar
thanks NRG it is then.
Old Apr 6, 2010 | 10:45 AM
bsmith100's Avatar
The type of hub you get will also depend on the type of steering wheel you want to use. The NRG hubs will work with their steering wheels as well as the Sparco and Momo steering wheels. So be sure that the steering wheel you want to use is compatible with the hub you get. They also sell adapters in case your steering wheel does not have a compatible bolt pattern for your hub.
Are you going to get a quick release? I wouldn't if I were you. Save the money. How often are you going to take the wheel off anyway?
Old Apr 6, 2010 | 11:54 AM
grumblemarc's Avatar
The Grumpiest
At least twice a day on the weekdays.
If you're going to get the NRG combo might as well go all in and get the lock for it as well.
Old Apr 6, 2010 | 03:58 PM
bsmith100's Avatar
I didn't notice that you had a Personal steering wheel you wanted to use. They use a different bolt pattern than the Sparco and Momo steering wheels. The NRG hub also uses the Sparco and Momo pattern. So if you want to use the NRG hub with a Personal steering wheel then you need an adapter.
The Personal steering wheels use the same bolt pattern as the Nardi steering wheels, so you either need a Personal hub or a Nardi hub.
Old Apr 6, 2010 | 04:36 PM
The Grumpiest
Get a Nardi to Momo hub adapter like this one.
http://cgi.ebay.com/ebaymotors/Nardi...item27b07445f5
Old Jun 17, 2020 | 06:59 AM
Mason Hebert's Avatar
i had ordered a nrg short hub and quick release but the hub wont fit its too small is there any suggestions on what to do
jdm95
Feb 3, 2010 10:01 AM
robble36
12
Sep 26, 2007 11:27 AM
iBrandon
Aug 17, 2006 05:18 PM
