hesitation issues?
Old Apr 1, 2010 | 05:56 PM
xuecivic's Avatar
Post hesitation issues?
i'm having issues with my car, i'm out of ideas on what it is i hope someone can help me. whenever i drive my car for awhile and the motor is warm i turn it off and let it sit for a couple of hours but after that i start if up again and drive it seems like the butterfly is stuck! when i step on the gas it hesitates and jerks, but when i let off the gas it seems like the butterfly is sucked and doesn't wanna go. i've cleaned the butterfly with throttle body cleaner and nothing, i replaced the sensor behind the intake manifold and nothing too. so please help me if you know what it could be? thanks
Old Apr 1, 2010 | 08:09 PM
josh89's Avatar
Default Re: hesitation issues?
Does it take a few second then go? Kinda rumbles around then your good to go or what?
If so it's the same problem I was having and one day it just stopped. Still does it every once in awhile but I just kill it and start it back up and I'm fine.
Old Apr 2, 2010 | 11:35 AM
xuecivic's Avatar
yeah sometimes when i turn it off it still does it, but most of the time it's ok cause i don't really drive it as much, and yea it takes a few seconds then go. everything works fine other then that, vtec, and coolant is fine. it gets worse when i down shift and hold it at a high rmp like at 5k or 6k it jerks back and forth
Old Apr 2, 2010 | 11:38 AM
American.Graffiti's Avatar
It almost sounds like you are having a MAP or TPS sensor problem.
Old Apr 2, 2010 | 11:44 AM
xuecivic's Avatar
you think so? but i have no check engine light, well when i start it up i don't have any until i drive it for like 20 min. then the check engine light come on, not sure what that is too.
Old Apr 2, 2010 | 11:55 AM
ChokolAwt's Avatar
jump the service connecter under the passenger side foot well and see what the code is. there's a how-to in this forum... use it.
Old Apr 2, 2010 | 12:02 PM
xuecivic's Avatar
yeah i'll try that see if any code will come up
93eghb
Aug 10, 2008 10:37 AM
Meatwad1355
Jul 1, 2007 08:12 AM
16bit_Villain
Mar 10, 2005 02:44 PM
Luserkid
Jul 22, 2004 05:54 PM
REDBARON
Nov 11, 2001 08:32 PM
