10k/8k = ?lbs??
lawlz it's funny seeing people that mostly have experience only with cheap Chinese-made coilovers and only seem to know kg/mm spring rates. I have always used lb/in for spring rates and that's what I know. I always have to convert kg/mm to lb/in to get an idea of how stiff the spring is.
Anyway, yea...metric system is way easier to use.
. But car guys look at you funny if you talk about springs in N/m
and kg/mm gives numbers that are convenient to work with I guess.
Convenience isn't the issue. 50kg/cm gives 447lb/in(~450), 60kg/cm 336lb/in (~325); so rounded lb figures can be just as easy to work with, so no argument there.
But, since 1kg/m = 9.8N/m, springrates in kg and N would differ in practice only by a factor 10 - which would give rise to confusion.
So long as we are talking about spring rates measured on the planet earth, I think we'll be ok. :D
Originally Posted by chargeR
True story . But car guys look at you funny if you talk about springs in N/m and kg/mm gives numbers that are convenient to work with I guess.
96 SOHC VTEC
Mar 30, 2003 07:52 PM
B18CXr
Dec 12, 2001 12:59 PM
The metric system isn't magic.
