Suspension & Brakes Theory, alignment, spring rates....
Question regarding adjustment of Koni Sports
Old Apr 1, 2010 | 10:16 AM
96hb's Avatar
Icon2 Question regarding adjustment of Koni Sports
I recently received and installed my new Koni's and GC's. When I first got the shocks I tested out each one to make sure I could adjust from full soft to full stiff before putting them on the car and each one worked fine. Now that they are on the car, I was messing around with them and I can't get my passenger side front shock to adjust more than a half turn or so towards full stiff. Has anyone had this problem before? Did I install something wrong or too tight? I also have the GC upper mounts on the front but my other shock adjusts fine (about 2 rotations from soft to firm).
Old Apr 1, 2010 | 07:03 PM
96hb's Avatar
Default Re: Question regarding adjustment of Koni Sports
Nevermind, I figured it out. Reading comprehension > me. I forgot to put 2 nuts on the shaft in the top hat to keep it from turning. It works fine now. I swear this always happens to me!
Old Apr 1, 2010 | 07:11 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
LOL good thing you figured it out. For something like that, though, you can usually call up Koni North America and they can help you out.
Old Apr 1, 2010 | 07:32 PM
96hb's Avatar
Haha! I was going to but they were closed when I got home. Plus I figured I'd better double check my work because it was very likely that the error was caused by me. I was right.
Old Apr 1, 2010 | 08:43 PM
racebum's Avatar
no idea what your rates are but the honda fwd chassis almost always responds well to a softer valving up front than you have in the rear. for example i'm on 500/430lb springs and have the fronts about half and the rear just off full stiff
Old Apr 1, 2010 | 09:24 PM
96hb's Avatar
Well I just have the standard GC kit right now with my shocks set to full soft. I am loving the ride at the moment.
Old Apr 2, 2010 | 05:45 AM
Community Builder
Why would you go with more damping on softer springs? That just sounds odd, as in either you front springs are underdamped (probably) or the rear ones are overdamped (doubtful).
Old Apr 2, 2010 | 07:48 AM
kristo's Avatar
Loved
RTFM
Note it also says to never adjust the shock fully (2 turns). "just off full stiff" is the farthest/stiffest you should go.
However "just off full stiff" seems rather extreme? From the Koni FAQ:
"If the car has performance upgrades (springs, wheel/tire packages, etc.) or the driver wants the car a bit more aggressive, most people find the optimum setting in the 1/2 to one full turn from the full soft range. Over the extended life of the damper or if the driver wants a specific firm handling characteristic, the dampers can be adjusted up higher. Very rarely will KONI ever need to be adjusted to the full firm setting"
Old Apr 2, 2010 | 08:25 PM
96hb's Avatar
Hehe. Well I have them set to full soft now and probably will more often than not. I just wanted to be sure I could adjust them. Nothing like spending $500 and the stuff doesn't work correctly. But like I said, it was my fault. I did read the directions, I just missed that part somehow.
bleedblue94
Suspension & Brakes
Sep 18, 2006 07:35 PM
JDM RHD eg6
Suspension & Brakes
14
Feb 1, 2005 10:21 AM
gsr-mike
Jun 18, 2004 05:55 PM
AcuraEL
Feb 27, 2003 04:55 AM
taytay333
Mar 25, 2002 09:07 PM
