Suspension & Brakes Theory, alignment, spring rates....
Rear Disk Conversion
Old Mar 31, 2010 | 07:47 PM
quiocho8o8's Avatar
Default Rear Disk Conversion
i got a set of rear disk brakes with the trailer arm assembly from a DA
can i use this set up on my EK?
Old Apr 5, 2010 | 07:28 PM
roastbeefrichie's Avatar
Default Re: Rear Disk Conversion
yes, the 90-93 integra DA rear trailing arm assembly w/ rear discs will bolt-up to your 96-00 EK civic;
the rotors & pads can be sourced from any 90-01 integra (excluding itr)
you'll need rear disc brake hoses, the drum hoses are too short
Originally Posted by BrakeExpert
after caliper installation, here is the CORRECT bleeding sequence:
Bleed the brakes Right Rear, Left Front, Left Rear, Right Front. You do not go farthest to closest with Hondas.
once your drum-to-disc conversion is swapped, get an alignment
Davidkak
15
Jan 11, 2011 02:29 PM
Adrenaline_Racing
Nov 9, 2005 04:24 PM
VisualEcstasy
17
Mar 28, 2003 01:16 PM
