RUST! Help with bubbles
Old Mar 31, 2010 | 02:03 PM
Momentum's Avatar
Default RUST! Help with bubbles
hey would i be able to just sand this down and repaint?
I want it fixed asap but i have a repaint coming for the whole car so i dont want to have to pay to get it fixed when im going to be painting the car in a couple of months.
Old Mar 31, 2010 | 02:25 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: RUST! Help with bubbles
Nope, it would come back right away!! That rust is through the metal, and can only be fixed properly by cutting out the metal. On the back side of that metal, is a lot of hidden rust you simply can't see yet
Old Mar 31, 2010 | 03:01 PM
red Teggie's Avatar
Well, to me, that doesn't look THAT bad. I'd try to strip the paint for the affected area and see how bad it actually is under the paint..
Sure, rust is very hard to get rid of, since it tends to come back very easily, but if it's surface rust, I don't see why you can't just sand it down to metal and do the treatment (sealing, painting, etc).
Old Mar 31, 2010 | 03:50 PM
Deetz's Avatar
Crazy Honda Guy
lol, that's how it starts out
Trust me, that rust has come from behind the metal in the quarter. I have owned enough Honda's to know about rear wheel rust.
Old Mar 31, 2010 | 03:51 PM
uASSboston's Avatar
TRIAL USER
yeah it sucks, i wish it was that easy.
Old Mar 31, 2010 | 05:08 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Something like POR-15 might help, over the back side of the metal, after you fix the front - never tried it, but have heard good things? Deetz is right though - best way is to replace.
Old Mar 31, 2010 | 05:18 PM
DVDr's Avatar
fixed exactly the same thing on one of the cars, Its rusting from the inside out.
You can grind it down and por 15 it and paint over it, but it will come back after a year.
Best thing is to but it out and weld a new piece in.
Old Mar 31, 2010 | 05:37 PM
Momentum's Avatar
Dont tell me that guys
Any idea what i should expect to pay to have this fixed at a shop?
Old Mar 31, 2010 | 06:12 PM
Deetz's Avatar
Crazy Honda Guy
You live next to Edmonton, go see a good body shop and get a quote......makes sense, doesn't it
Old Mar 31, 2010 | 06:19 PM
95soul's Avatar
If it isnt all the way through the metal, you can grind the rust off, and just hit it with some body filler, and repaint. Problem solved. But if its through the metal, I would just get another fender from a junkyard. Easier than welding a new piece in. The reason I love living in the south is our cars (especially hondas) never get rust.
Old Apr 1, 2010 | 02:04 PM
starion88esir's Avatar
As has been said, if it's bubling through the paint it is completely rusted through. No ifs ands or buts about it. It's shot and only cutting it out and welding a patch panel will fix it.
Por 15 is a band aid. It is ONLY good for surface rust and you still need to remove everything you can before applying it to get good results.
Bondo is an even worse band aid and you should just avoid painting it if that's your fix, because you're paint will crack in no time.
After you put in your patch panel be sure to use a QUALITY undercoat to prevent it from happening again.
Old Apr 1, 2010 | 05:07 PM
chcivic97's Avatar
don't waste your time patching it. It will just come back. Has to be cut out.
Blacknight117
Paint and Body
Sep 26, 2011 04:35 PM
pumafeet10
Aug 2, 2005 07:49 PM
JM Performance
Jul 11, 2003 09:49 AM
IdotheSHOCKER
21
Jun 26, 2002 02:09 PM
Nick H
Mar 31, 2002 04:44 PM
