D16z6 build.
Old Mar 30, 2010 | 05:11 PM
JohnnyWash1's Avatar
Default D16z6 build.
I'm putting together a D16z6 engine for my daily. I have the head and block, and am currently looking at a JDM intake manifold/TB combo for cheap. What is the difference? Should I grab this combo and be done with it? Thanks.
Old Mar 30, 2010 | 05:22 PM
Gunmetal_B20_Hatch's Avatar
Default Re: D16z6 build.
nothing
Old Mar 30, 2010 | 05:55 PM
SHG_Claudio's Avatar
Get a D16Y8 manifold or get an aftermarket one like edelbrock
Old Mar 31, 2010 | 07:38 AM
I'm trying to do this as cheaply as possible. So far, I've heard the JDM manifold will work. Is this true?
Old Mar 31, 2010 | 07:52 AM
92shade's Avatar
sure it will work but this isnt a build your just putting a stock motor together right?
Old Mar 31, 2010 | 08:26 AM
If you're on a budget, the D16Y8 ('96-00 Civic EX) intake manifold is your answer. With its short runners and fat plenum this is essentially putting a Type R intake manifold on a B series, but still not nearly as good as aftermarket units. The JDM intake manifold you're probably referring to is the D15B probably. Its equal to the D16Z6 motor here. It will most likely be about the same.
I don't have experience with it so keep this thread floating to get more answers. As long as they have FITV and IACV too like here then you should be fine.
Old Mar 31, 2010 | 11:13 AM
Yes, I made a typo in the title. I'm simply putting a stock motor together.
Thanks for the advice. I've heard the Y8 manifold is better for performance; however, I have located a JDM D16z6 manifold and TB for cheap ($40).
Old Mar 31, 2010 | 12:55 PM
There's no such thing as a jdm D16Z6. The jdm equivalent is the D15B, JDM motors don't have a number at the end. Go for it. Sounds like a good price
Old Mar 31, 2010 | 05:13 PM
Thanks. In the ad he labeled it "D16 JDM intake manifold and TB". I simply assumed it was the Z6.
Old Mar 31, 2010 | 06:14 PM
Jimster480's Avatar
+1
Y8 Manifold is the best D series Manifold.
Old Apr 2, 2010 | 03:26 PM
R Benitez's Avatar
TRIAL USER
I want to rebuild my Sol's D16 too. I would like to get as close to 200hp as
possible. I don't want to use a turbo or supercharger, N.O.S. etc. I have owned my Honda since 94 and got 380,000 miles out of it. I don't intend to race around but a little extra muscle over stock would be nice. Any help or advise would be appreciated. I don't know much about the honda tuning world.
Thanks
Old Apr 2, 2010 | 04:16 PM
chinochanginc's Avatar
get the stock z6 mani and a integra tb
Old Apr 2, 2010 | 05:45 PM
Jimster480's Avatar
B series TB is useless unless the plenum is bored out.
Old Apr 2, 2010 | 08:53 PM
Thanks
200hp NA? I don't think so. Its possible but its very expensive and not worth it at all. 130WHP would be more reasonable goal. Intake, header, exhaust and cams could probably get you in that zone. Yeah expensive as hell for not a whole lotta power, imagine 200whp.... 200whp is fast too btw.... Swap or boost.
Old Apr 3, 2010 | 08:28 AM
Jimster480's Avatar
if you boost it you can make 200WHP easy. Otherwise you can do intake, header, exhaust, E3 plugs, Heat Sheilding Intake Manifold Gasket, Port Matched Y8 Intake Manifold, and Throttle Body Coolant Bypass. With all that you should make atleast 130WHP.
miggy23
Feb 4, 2010 02:54 AM
acuratech
Aug 18, 2002 06:43 PM
Slow Rocket
Feb 24, 2002 10:57 AM
Redline130
Aug 21, 2001 11:41 PM
