Suspension & Brakes Theory, alignment, spring rates....
Rear Disk Conversion
Old Mar 30, 2010 | 07:58 AM
EFficial's Avatar
Default Rear Disk Conversion
I have a 89' ED6 and was wondering what it will take to install a 90' DA9's rear disks onto it. THX!
Old Apr 5, 2010 | 07:44 PM
roastbeefrichie's Avatar
Default Re: Rear Disk Conversion
yes, you'll need to source the complete rear trailing arm w/ rear disc.
it doesn't specifically have to be from a 90-93 integra DA.
any 94-00 integra DC, civic/crx EF Si, del sol Si, 99-00 civic Si rear disc trailing arm will work on your 89 civic ED6
you'll need rear disc brake hoses, drum hoses are too short. (use a 10mm flare wrench when removing the hose to prevent stripping)
Originally Posted by BrakeExpert
after caliper installation, here is the CORRECT bleeding sequence:
Bleed the brakes Right Rear, Left Front, Left Rear, Right Front. You do not go farthest to closest with Hondas.
once your drum-to-disc swap is complete, it's a good idea to get an alignment
http://crxcommunity.com/viewtopic.php?t=13990
Old Apr 17, 2010 | 04:51 AM
novaksaotome's Avatar
do any of you guys know if a 95 Ferio rear trailing will fit a 97 EJ9 civic for the rear disc conversion?
Old Apr 17, 2010 | 05:44 AM
phunhaus's Avatar
Yes. All 90-01 Integra and 88-00 Civic have the same dimension trailing arms. All are interchangeable.
Old Apr 17, 2010 | 05:58 AM
sal-boss's Avatar
sorry to jump in ...
i recently bought a 89 civic sedan and i have a now gutted 92 integra turnd out to be a gold mine ... but reading this you say that i can take the rear assembly and it will fit my 89 civic sedan????? for the disc conversion!! do you know what else will swap?
Old Apr 17, 2010 | 10:52 PM
attn: this is EFficial's thread, should really hit the new topic button next time
ok...i'll play:
regarding the 89 civic sedan: yes, the rear disc trailing arms will bolt on.
also from the 92 integra: take the front knuckles, calipers & b18a1 swap.
the master booster/cylinder: https://honda-tech.com/forums/suspension-brakes-54/da-booster-master-cylinder-ef-2570678/
For those of you with a soggy brake pedal after caliper installation, here is the CORRECT bleeding sequence:
Always bench bleed the Master cylinder when replacing the master cylinder, ABS unit, or proportioning valve.
once everything is swapped. get an alignment
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/da-knuckles-vs-si-knuckles-ex-knuckles-big-brakes-2140287/
Old Apr 22, 2010 | 08:06 AM
EFficial's Avatar
Thank you very much fellas!
ill be doing that in a couple weeks as soon as i wire up my B18a1 and get it started
Old Apr 22, 2010 | 08:35 AM
dj theoretic
Jun 3, 2008 10:24 AM
ek4ferrio
Oct 9, 2006 07:01 PM
acurateggy93
Apr 12, 2005 10:12 AM
bigstevo106
Sep 21, 2004 06:23 PM
Hatch_Back_97
Mar 28, 2004 08:05 PM
