power sterring question help
Old Mar 30, 2010 | 07:32 AM
crx-b18c's Avatar
Default power sterring question help
i have 99 honda accord v6 i replace my power steering pump 3 times in last 2 months someone can help me to find out what causing this thanks in advance
Old Mar 30, 2010 | 09:05 AM
arkangel2487's Avatar
Default Re: power sterring question help
u getting quality honda stuff? and is ur cooler(if u have one) working efiecently
Old Mar 30, 2010 | 09:36 AM
slomofo's Avatar
GDD Member
Honda fluid?
Pump aligned properly with the rest of the pulleys?
Any leaks?
Bleed the system properly?
Are you sure the pump is really going bad?
Is this an Autozone pump?
Old Mar 30, 2010 | 10:27 AM
crx-b18c's Avatar
buying fluid and pump from advance no leaks i dont know if the pump or other component i thought is the pump how i can bleed the system?thanks
Old Mar 30, 2010 | 12:54 PM
HonBeer's Avatar
Buy a Reman from the Honda Dealer
Old Mar 30, 2010 | 07:43 PM
i shoulda asked this first, when u say fail u mean hard to steer, noisy, leaky. and i imagine the "new" pump works at first but how long does it take to fail again
Old Mar 30, 2010 | 08:41 PM
crx-b18c's Avatar
hard to steer last long couple days
Old Mar 31, 2010 | 05:09 AM
when u put the advanced pump in does it work for a lil bit. if it doesnt, the seals in the rack are bad or u have a restriction. if it does then u need to take that garbage off and get a honda pump
smcdonaldaz
Acura TSX
Dec 10, 2019 01:21 PM
mem94043
Mar 13, 2011 07:16 PM
Luward
Honda CR-V & Element
Nov 27, 2010 12:25 PM
98greensi
Oct 29, 2009 12:12 PM
earthworm
Jun 2, 2005 08:37 PM
