No VTEC on non VTEC engine
Old Mar 28, 2010 | 03:32 PM
Armychris89's Avatar
Icon6 No VTEC on non VTEC engine
I recently bought a 1993 honda civic ex coupe. The original engine that was in the car was a d16z6, now it has a d15b8,(previous owner didn't change the oil and rod went through the block. Car runs and drives fine but, the problem i'm having is code 21 and 22 pop up on the mil light, which means a vtec valve and solenoid malfunction. Is there a way to delete the vtec sensors and get the mil light to go away?
Old Mar 28, 2010 | 03:58 PM
-__-'s Avatar
Default Re: No VTEC on non VTEC engine
there probably is but i wouldnt worry about those codes. you could always change the ECU to a non-vtec ECU and problem solved.
Old Mar 28, 2010 | 04:22 PM
HondaPartsHero's Avatar
Technical Hero
x2
SargeSlapnuts
Oct 28, 2009 09:57 PM
bmxmacdaddy
Feb 28, 2009 01:49 PM
CTR_B
Mar 20, 2008 10:21 PM
just_a_sohc
Dec 27, 2001 08:52 AM
