Vitara scat wristpin question
Old Mar 27, 2010 | 05:41 PM
NonovUrbizniz's Avatar
Loved
Default Vitara scat wristpin question
I'm trying to check clearances for my build. D16 vitara scat rods.
Are the wristpins supposes to be press in or floating?
These are definately press in. I bought to rods second hand so they might be the wrong rods. Pins definately float in the pistons.
I heated up the rods and froze the wristpins and that still didn't do it. I actually have one wristpin stuck 3/4 of the way in the rod now.
Old Mar 28, 2010 | 06:33 AM
Loved
Default Re: Vitara scat wristpin question
Nobody ?
Old Mar 28, 2010 | 07:19 AM
95civhb's Avatar
bump for an answer... did you get the box with the rods??
Part No Short No Description Rod Length Crankpin Wristpin Bewidth
2-5394-1771-898-748 65394187 4CYL. 5.394" 1.771" .748" .898"
2-5394-1771-935-827 65391498 4CYL. 5.394" 1.771" .827" .935"
That's from Scat's site... pretty sure You want the first option..
Somebody help this guy out?
Old Mar 28, 2010 | 12:57 PM
Loved
I do have the box I'll go check and measure everything as well.
Old Mar 28, 2010 | 02:17 PM
95civhb's Avatar
maybe you got some b18 rods there?
They are the same length as the d series, (5.394) , but a larger wrist length...
Old Mar 29, 2010 | 06:46 AM
Loved
I'm just shocked no one could just spit out whether they're supposed to be press in or floating...
I'll measure them tonight and try to give scat a call.
Old Mar 29, 2010 | 01:48 PM
welfarepc's Avatar
they should be floating.
Old Mar 29, 2010 | 03:46 PM
Loved
Thanks that's what I thought.... Add yet another item I'm going to repurchase since I tried to cheap out on initially. Ugh
fj ibeams here I come.
Old Mar 30, 2010 | 10:42 AM
welfarepc's Avatar
just use a brake cylinder hone to open it up a little or take them to a machine shop.
4door hobo
Oct 19, 2006 03:03 PM
b16sellout
Nov 9, 2004 08:47 PM
racecarpete
Oct 20, 2004 01:50 PM
quik sol
Aug 20, 2004 08:07 AM
