Eagle rods wont fit with CP pistons!! HELP!!
Im in the process of my build and its time for installing the pistons and rods, i went to slid the rist pin into the rod, but the rod hole is way to small, i called cp and they are the right pistons for my ls-vech turbo and eagle is closed for today, the rod is stamped CRS-5394-A but on the eagle site there called CRS-5394-A3D. dose the 3D make the diffrence because i cant find any rods with the same part number as the one i have or did eagle leave off the 3D on the rods. Any help would be greatfull.
Re: Eagle rods wont fit with CP pistons!! HELP!! (4door hobo)
The 5394 number is the center to center length of the rod (5.394")
The b18a and the D16 series rods have the same length but the D series uses a smaller wrist pin size. It looks like you have the D rods rather than the B rods
hackish
09-02-2003 05:06 PM
