Can you block the Fitv on a 95 civic?
Old Mar 26, 2010 | 05:30 PM
95civicdb's Avatar
Default Can you block the Fitv on a 95 civic? surging idle??
So my honda is having an idle problem only at cold start and it idle surges from 1500-2000rpms for about a minute and then sits at like 1800rpms until it gets alittle warm then it idles at normal 450rpms. So ive been hearing that the Fast Idle Thermo-Valve could be the problem, and i have also heard that you can block it off.
Any info on this would be great. Thanks
Old Mar 26, 2010 | 05:52 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: Can you block the Fitv on a 95 civic?
Originally Posted by 95civicdb
So my honda is having an idle problem only at cold start and it idles at 2000rpms until it gets warm then it idles at normal 450rpms. So ive been hearing that the Fast Idle Thermo-Valve could be the problem, and i have also heard that you can block it off.
That acctually sound pretty normal. All of my Hondas idle at about +/- 1800 rpms when it's cold.
FITV is supposed to raise the idle until the coolant warms up, then it closes and the IACV takes full control of idle air flow.
Old Mar 26, 2010 | 11:15 PM
WeakSauce92's Avatar
Yup, it seems like normal operation for any vehicle actually
Old Mar 27, 2010 | 03:43 AM
92shade's Avatar
idle when warm should be about 800 +/- 50
Old Mar 27, 2010 | 05:50 AM
95civicdb's Avatar
I meant to say it surges from 1500-2000rpms when its cold and only lasts like a 1minute and then its fine, just idles at steady at 1800ish rpms until the car gets warm
Old Mar 27, 2010 | 06:55 AM
BryanM.'s Avatar
Resident Gearhead
My OBD1 B16A did that for years, never bothered me, but if it drives you nuts try cleaning the FITV. There are a couple of good DIY threads kicking around here that still have working pictures.
Normal. It's trying to get warmed up.
Old Mar 27, 2010 | 07:04 AM
BryanM.'s Avatar
Resident Gearhead
'92-'95 Civic (with IACV connected)
D15Z1
Manual....600 +/- 50 rpm
Auto.......700 +/- 50 rpm
All others
Manual....670 +/- 50 rpm
Old Mar 27, 2010 | 08:30 PM
95civicdb's Avatar
Anybody ever bypassed the fitv tho?
BlackJacket
Dec 8, 2013 10:07 PM
b20bFourDoorCivicLX
Apr 16, 2013 08:34 PM
DO/\/\O
14
May 9, 2011 05:56 PM
jdmgeezer
Dec 9, 2007 11:23 PM
del_parker
Jul 22, 2003 06:53 PM
