help with instument cluster
Old Mar 26, 2010 | 12:07 PM
Manlion's Avatar
Default help with instument cluster
my speedometer just stopped workin, everything was fine til today it just shat the bed everything else works but the speedometer.. anyone got any ideas, how can i tell if its a sensor or the cluster itself?
thanks in advance
Old Mar 26, 2010 | 12:37 PM
Manlion's Avatar
Default Re: help with instument cluster
i saw something in another thread about if the cruise control worked then its not the sensor or something or other? and something else about a a fuse???
Old Mar 27, 2010 | 04:51 AM
Manlion's Avatar
bumppp...
i checked and cruise control isnt working.. what should i do now?
Old Mar 27, 2010 | 09:21 AM
zillacles's Avatar
no CEL? Could be VSS, although I woulda thought tacho would stop working as well
Old Mar 27, 2010 | 04:55 PM
fleetw00d's Avatar
The tach doesn't operate off the VSS. If the odometer works, it is not the VSS. If speedo, odo, and cruise don't work, then it may be the VSS. Check the fuses. Check voltage to the VSS. If you have a wiring diagram, find a spot where you can back probe the VSS signal wire (I was able to do this at the lower left connector to the gauge clusted in my 93, behind the cruise control switch), check to see if you're getting a pulsing voltage when a wheel is rotated (jack one wheel up, rotate it by hand). If the VSS has voltage, but doesn't provide a signal, the VSS is bad.
Old Mar 28, 2010 | 06:14 AM
Manlion's Avatar
ok ill check that out.. thanks so muchhh
Old Mar 28, 2010 | 09:36 AM
bseriescrxsi's Avatar
if speedo and tach dont work and there is no CEL it is most likely NOT the VSS these cars have issues with a board internally in the cluster that must be repaired/replaced...one board could be the main cluster board but it is most likely the board attached to the back of the sppedo/odo unit itself
Old Mar 29, 2010 | 03:19 PM
Manlion's Avatar
i realized the cruise control did work i wasnt going fast enough so i replaced the intrument cluster and it seems to be all good..
now i have a new light that i want to get rid of.,. the SRS light is starting to bug me.. the code reader i have doesnt read that.. i tried the FAQ and the thread aboutu clearing the SRS light no longer works http://www.ozaccord.com/forums/showthread.php?t=39
input on this would be aprreciated.. thanks for all the help and guiding me through everything
Drola
Sep 14, 2011 07:26 AM
gorillapno
May 26, 2008 09:38 PM
redboost10
May 1, 2008 09:22 AM
JDM Dylan
14
Mar 5, 2008 09:11 PM
cmasonrun
13
Jul 17, 2007 11:34 AM
