No crank after turbo kit install!! need help
Old Mar 25, 2010 | 03:25 PM
almostjdmeg's Avatar
Default No crank after turbo kit install!! need help
I just finished installing a turbo kit on my integra. I put my key to the run position, everything worked, the fuel pump primed, the cel went off, everything was fine. Then when i turned the key to start it i hear one click, then nothing, and i turned the key back to the run position and the cel just faintly is still on. Then the main relay starting clicking but stopped when i turned the key to the off position. Someone please tell me something that may help. Thanks
Old Mar 25, 2010 | 03:26 PM
sohc eg's Avatar
Default Re: No crank after turbo kit install!! need help
battery is dead........relays are clicking because you dont have enough juice in the system
Old Mar 25, 2010 | 03:29 PM
steveo135's Avatar
or battery cables may be loose
Old Mar 25, 2010 | 03:34 PM
I already charged the battery, and the battery cables are tight for sure
Old Mar 25, 2010 | 04:07 PM
sohc eg's Avatar
the relay clicks when the starter wont turn because the battery is not providing enough power to the system. thats just how it is...no argument.
Old Mar 25, 2010 | 04:19 PM
I agree with you yes, but would the main relay be clicking when the key is on the run position and not actually turned to the start position?
Old Mar 25, 2010 | 05:11 PM
I feel really stupid, it was just a bad ground, sorry for wating your guys time. Thanks
Old Mar 25, 2010 | 05:20 PM
boostedcivicsir's Avatar
Mr. Badwrench
i know this is a place to help, but people are so quick to go and run for the parts dart board.
if it ran before, you need to go back and look at what was changed. start there.
i know you have your issue fixed, this is kind of a helpful hint.
my favorite is i just adjusted my valves, now i have a miss/wont start
i replaced dizzy, ecm, coil, alternator, battery, wipers, sunroof, and still wont run.
it is as easy as goin back over what was changed. (thats a hypothetical scenerio)
in that situation, it is just about always wrong firing order.
Old Mar 27, 2010 | 11:14 AM
TEAM ASSASSIN SI's Avatar
i agree lol
Old Mar 27, 2010 | 11:42 AM
Kyle R's Avatar
Glad that you got it figured out.
ek coupe
10
Mar 5, 2010 05:02 PM
viciousef9
Feb 20, 2008 03:47 PM
crxpwr1
18
Jun 30, 2007 09:03 AM
deftones0817
Jul 14, 2005 08:17 AM
tan2
Nov 4, 2002 10:10 AM
