Is this shift fork moving as it should? *PICS*
Old Mar 25, 2010 | 03:16 PM
Tulo's Avatar
Default Is this shift fork moving as it should? *PICS*
I'm having trouble diagnosing why this LS/vtec w/gsr trans and Quaife LSD is getting stuck in gear, as well as won't go into the next gear when shifting. It seems to only do it at high RPM, and after a pull has already been done.
Does the travel in the shift fork pictured below look normal? Pics were taken with clutch pressed all the way in, and not pressed at all. TIA!
Old Mar 25, 2010 | 07:37 PM
Rooftop voter's Avatar
Default Re: Is this shift fork moving as it should? *PICS*
In for info.
Old Mar 25, 2010 | 07:52 PM
egsleepercivic's Avatar
looks pretty good have you checked your fluid level in the trans ?
matcat86
Transmission & Drivetrain
13
Jul 18, 2014 09:46 AM
Russyo
Aug 11, 2011 07:03 AM
domestic_rice
Dec 2, 2009 07:06 PM
NOOdS
Apr 20, 2009 11:04 AM
servion
Jan 30, 2003 06:54 PM
