can a stock y8 handle 7psi and nitrous
Old Sep 9, 2002 | 09:40 AM
cjames235's Avatar
Default can a stock y8 handle 7psi and nitrous
probly not but just wondering maybe like a 20 shot or something
Old Sep 9, 2002 | 11:17 AM
CovertFI's Avatar
Default Re: can a stock y8 handle 7psi and nitrous (cjames235)
y dont you just run 10 psi?
Old Sep 9, 2002 | 12:15 PM
bretx0r's Avatar
Default Re: can a stock y8 handle 7psi and nitrous (CovertFI)
indeed.
nitrous is the devil
Old Sep 9, 2002 | 12:19 PM
Firedrake's Avatar
Default Re: can a stock y8 handle 7psi and nitrous (bretx0r)
Is the Y8 sohc vtec? We have a Y7? (sohc non-vtec) stock motor making around 230 whp on like 12 lbs on a mitsu 16G turbo with no problems running vafc hack and 450's.....
Nitrous is the devil Well, on the dyno it is anyways......nitrous backfire makes 14psi stock B18C go boom on the dyno
Brian
Old Sep 9, 2002 | 12:21 PM
mntdewred's Avatar
nitrous is only the devil because the user doesn't know the proper way of using it. nitrous can be very helpful if the user is knowledgeable of the substance.
and why would you waste your money on a whole nitrous setup for only a 20 shot? if your Y8 is in good shape, it should be able to handle 10 psi if tuned properly.
just stick with turbo
Old Sep 9, 2002 | 03:58 PM
cjames235's Avatar
Default Re: can a stock y8 handle 7psi and nitrous (mntdewred)
thanks for the replys. what kind of mods will i need to go from 7 to 10 psi without building the engine? i know it involves a lot of tuning.
Old Sep 9, 2002 | 04:49 PM
PrecisionH23a's Avatar
what the **** are you people talking about? According to fast and furious he can run 10psi EASY with a 75 shot of naWzzzz.
If you want to go from 7 to 10 psi i would recommend
larger injectors
intank fuel pump
adj fpr
fuel rail
hondata
good dyno tuning
some more good dyno tuning
[Modified by GudeH23a, 8:51 PM 9/9/2002]
Old Sep 9, 2002 | 05:15 PM
cjames235's Avatar
Default Re: can a stock y8 handle 7psi and nitrous (GudeH23a)
shut up f&f is the stupidest movie ever thats why i said that i probably cant spray on it. im just trying to get some info here. there are too many bitches on this board who cant answer a simple question without giving someone ****. i didnt think that a stock y8 could handle 10psi. so again what exactly will i need to run 10psi on a stock block.
Old Sep 9, 2002 | 05:17 PM
Firedrake's Avatar
http://www.solid-technology.com
Look under customer cars at our civic, that's what you need to run 10 psi.....it now has a fuel pump, 16G, clutch, and some other goodies.....
Brian
Old Sep 9, 2002 | 05:34 PM
i guess you cant take a joke. i answered your simple question, lose your attitude.
mntdewred's Avatar
before you get bent out of shape, he was just joking with the f&f similarity.
it will be o.k.
and a stock y8 block on 10 psi of boost will only be as reliable as the tuning. if you never tune it, buh-bye motor.
Old Sep 9, 2002 | 05:47 PM
KoRE's Avatar
they are right about the tuning i ran 11psi with the afc hack and boom....on the way home from hot importnights too.... it's ok thoguh cause i'm building it to run 12-15psi and nitrous
Old Sep 9, 2002 | 06:00 PM
turboex's Avatar
Default Re: can a stock y8 handle 7psi and nitrous (KoRE)
hack = bang, hense the word hack
hondata = power!
J/K but everytime I do some thing the cheep way it always cost more in the long run.
Old Sep 10, 2002 | 06:40 AM
cjames235's Avatar
Default Re: can a stock y8 handle 7psi and nitrous (turboex)
sorry for freakin out yesterday i was pissed off at some other ****. thanks for the help though
Old Sep 10, 2002 | 09:02 AM
autoEXturbo's Avatar
10psi on a y8 is pushing it some, i know some have done it. I did 8psi with safc, 440's, vortech fmu 12:1 disk, and 255lph fuel pump. I wouldn't recommend doing the hack, out of 3 friends that have done it, only one of their cars is on the street at any given time.
Old Sep 10, 2002 | 09:30 AM
zcivic91's Avatar
Default Re: can a stock y8 handle 7psi and nitrous (autoEXturbo)
i wouldlt even think of going past 8psi..let alone n2o..
comeone isnt ur car got plenty of speed as it is?? i know some times we want more..but dont do it unless u pan on doing a rebuild or repacing the motor all together and waiting for ur car to get fixed..
SOHCNightmare
26
Dec 29, 2006 04:06 PM
ej8dude
Dec 1, 2005 05:11 PM
NACvicSi
May 31, 2005 12:25 PM
Malakai
Aug 22, 2004 09:30 AM
sammydhoff
19
Jun 11, 2004 04:58 AM
