shot of nos?
Old Aug 17, 2004 | 10:34 AM
Malakai's Avatar
Default shot of nos?
I was wondering what u guys think would be the best shot of n2o to use on a stock GSR motor?
Old Aug 17, 2004 | 10:41 AM
spyderracing's Avatar
Default Re: shot of nos? (Malakai)
NO2 is the shot, NOS is the brand name. A 50-75 shot is ok for stock.
Old Aug 17, 2004 | 12:15 PM
FF DRFT's Avatar
r u going to be streetracing?!
for most NAWS.
Old Aug 17, 2004 | 12:29 PM
DruWO's Avatar
Default Re: shot of nos? (FF DRFT)
for ff "DRFT"ing....
haha...j.k
edit: 50 to 75 shot should be straight. I ran like a 75 shot on my stock y8 for a while, and compression is still perfect in all 4 cylinders.
Old Aug 17, 2004 | 12:35 PM
Default Re: shot of nos? (DruWO)
on me no2 is nitrogen dioxide
Old Aug 17, 2004 | 02:24 PM
FF DRFT's Avatar
lol my ebrake doesnt work too well- so ff drifting is basically impossible for me...
Nitrous-- good for one thing-- hitting whippits!
Old Aug 17, 2004 | 02:42 PM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FF DRFT &raquo;</TD></TR><TR><TD CLASS="quote">r u going to be streetracing?!
for most NAWS.</TD></TR></TABLE>
Why? What is wrong with nitrous?
for you.
Old Aug 17, 2004 | 04:54 PM
FF DRFT's Avatar
Default Re: shot of nos? (RyanCivic2000)
I said for MOST nitrous.
It's gay. Get some real hp, like a big motor, and then get a turbo, and then build it, and MAYBE then get nitrous. ITS AN OPINION FAWKER. LIVE WITH IT OR CRY SOME MORE.
Old Aug 17, 2004 | 07:10 PM
Killer_B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Malakai &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering what u guys think would be the best shot of n2o to use on a stock GSR motor?</TD></TR></TABLE>
a healthy, Stock Gsr can handle a 75shot with ease. as long as it jetted properly, you'll be fine. just make sure your car is running well. ie, fresh (cold) spark plugs, healthy ignition, healthy fuel supply/pump and keep you timing somewhat retarded when spraying.
i sprayed a stock B16 with a 120shot Direct Port for over a year. i cracked a couple of pistons at first becuz my jetting was not correct. after it was jetted properly i didn't have any problems.
Old Aug 17, 2004 | 07:45 PM
Malakai's Avatar
thanx for the reply
Old Aug 17, 2004 | 09:44 PM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FF DRFT &raquo;</TD></TR><TR><TD CLASS="quote">I said for MOST nitrous.
It's gay. Get some real hp, like a big motor, and then get a turbo, and then build it, and MAYBE then get nitrous. ITS AN OPINION FAWKER. LIVE WITH IT OR CRY SOME MORE.</TD></TR></TABLE>
You're gay. If you think real hp means having a big motor, what the hell do you have a Honda for?
Old Aug 22, 2004 | 02:35 AM
tekstyle's Avatar
Default Re: shot of nos? (spyderracing32)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spyderracing32 &raquo;</TD></TR><TR><TD CLASS="quote"> on me no2 is nitrogen dioxide
thats why its called N20: nitrous oxide
if there's N30, it will be called nitrate oxide. forgot what the nomenclature for 1 N is.
Old Aug 22, 2004 | 06:55 AM
turboimports's Avatar
Default Re: shot of nos? (tekstyle)
Yeah.
Get a NOS system. Zex works, but its complicated and has and hasn't work for my crew.
-Lor
Old Aug 22, 2004 | 07:35 AM
Killer_B's Avatar
Default Re: shot of nos? (turboimports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboimports &raquo;</TD></TR><TR><TD CLASS="quote">Yeah.
-Lor</TD></TR></TABLE>
i disagree.
it doesn't get easier than ZEX, its dummy proof. where as NOS might require you to change the suggested jetting.
i have always used NOS and i could never use the jetting that they suggested. they give you the jetting for conditions if your car is mostly stock. at least thats how it seems. i would call them, give them my fuel pressure and desired *SHOT* of nitrous. it never worked. they design their jetting to be a little on the Rich side. having a 255(high pressure) pump in my car threw the jetting off.
anyhow, i installed a couple of Zex kits and it doesn't get any easier. i never had to modify their suggested jetting.
btw, NOS and NX have always been my choice of nitrous kits. i think Zex is for pussies but i wouldn't want "Zex Man" on HT to hear me say that.
Old Aug 22, 2004 | 07:42 AM
Force-Fed 92 Vx's Avatar
In my experience a ZEX kit is the best on the market and fool proof with a 75 shot. Made good times and good power on my sohc. Good luck!
Old Aug 22, 2004 | 09:30 AM
SiR831's Avatar
you gonna use the plate system specifically for the GSR intake manifold?
Modified by SiR831 at 5:19 PM 8/30/2004
Importn2oRacer
Aug 1, 2008 02:00 PM
juanintec
28
Jul 16, 2008 06:00 PM
bootlegtrader
Jul 26, 2005 11:12 PM
92 CiViC gsR
May 20, 2002 03:25 PM
GSRacer
Jul 18, 2001 07:22 PM
