ODB0/ODB1
Pre-OBD systems use peak & hold type injectors with a resistor box. OBD-1 systems use saturated injectors with no resistor box.
You can use the pre-OBD injectors with an OBD-1 system, but you will need to run them with a resistor box, which will require some wiring.
http://www.hondata.com/techinjectorwiring.html
pinecone
Apr 25, 2006 06:41 AM
