Y7 fuel rail on Y8 intake manifold?
Old Mar 25, 2010 | 08:45 AM
zach1288's Avatar
Default Y7 fuel rail on Y8 intake manifold?
I am swapping my Y7 intake manifold for a Y8 and had a question.
Can I use my Y7 fuel rail on the Y8 intake manifold?
Thanks,
Zach
Old Mar 25, 2010 | 11:51 AM
zach1288's Avatar
Default Re: Y7 fuel rail on Y8 intake manifold?
Bump
Old Mar 25, 2010 | 12:06 PM
Anon51's Avatar
i believe you can. the only thing is you would have to run a longer fuel return line.
Old Mar 27, 2010 | 06:58 AM
zach1288's Avatar
bump
Old Mar 27, 2010 | 02:03 PM
backyard_concepts's Avatar
yes u can but use y8 injectors, if you do a search on here or d series.org or even just google. you will find a load of information for that swap. Good luck.
Old Mar 27, 2010 | 02:26 PM
D Griff's Avatar
You're putting a Y8 manifold on your Y7 right?
You can DEFINITELY use your Y7 fuel rail. Use your Y7 injectors! And you won't have to make any modifications. I'm positive of this, I've done this swap multiple times. I hope this helps.
The Y8 injectors will make your Y7 run rich.
Old Mar 27, 2010 | 03:05 PM
zach1288's Avatar
I have aftermarket injectors because of my turbo setup, i will be using those.
Old Mar 27, 2010 | 03:16 PM
D Griff's Avatar
Good deal.
ozh_hawaiian
Oct 23, 2011 03:00 PM
Tyla12
Nov 28, 2010 01:45 PM
kmeng
Feb 26, 2009 12:42 PM
Skinflute22
Aug 5, 2005 10:33 AM
