Y7 fuel rail on Y8 intake manifold?
Old 03-25-2010, 08:45 AM
zach1288's Avatar
Default Y7 fuel rail on Y8 intake manifold?
I am swapping my Y7 intake manifold for a Y8 and had a question.
Can I use my Y7 fuel rail on the Y8 intake manifold?
Thanks,
Zach
Old 03-25-2010, 11:51 AM
zach1288's Avatar
Default Re: Y7 fuel rail on Y8 intake manifold?
Bump
Old 03-25-2010, 12:06 PM
Anon51's Avatar
i believe you can. the only thing is you would have to run a longer fuel return line.
Old 03-27-2010, 06:58 AM
zach1288's Avatar
bump
Old 03-27-2010, 02:03 PM
backyard_concepts's Avatar
yes u can but use y8 injectors, if you do a search on here or d series.org or even just google. you will find a load of information for that swap. Good luck.
Old 03-27-2010, 02:26 PM
D Griff's Avatar
You're putting a Y8 manifold on your Y7 right?
You can DEFINITELY use your Y7 fuel rail. Use your Y7 injectors! And you won't have to make any modifications. I'm positive of this, I've done this swap multiple times. I hope this helps.
The Y8 injectors will make your Y7 run rich.
Old 03-27-2010, 03:05 PM
zach1288's Avatar
I have aftermarket injectors because of my turbo setup, i will be using those.
Old 03-27-2010, 03:16 PM
D Griff's Avatar
Good deal.
ozh_hawaiian
10-23-2011 03:00 PM
Tyla12
11-28-2010 01:45 PM
kmeng
02-26-2009 12:42 PM
Skinflute22
08-05-2005 10:33 AM
Quick Reply: Y7 fuel rail on Y8 intake manifold?
