My radiator and fan, pics inside
Old Mar 25, 2010 | 07:32 AM
R.A.T.'s Avatar
Default My radiator and fan, pics inside
I had a smaller fan before but now this fan is the SPAL fan. I can`t center it because the downpipe passes in front of the rad.
The section of the fan that is not on the rad, I`m planning to put a piece of plastic (like the crazy carpet plastic) so nothng goes flying in to the blades.
So what do you guys think? Is this ok? Any other suggestions?
Old Mar 25, 2010 | 07:41 AM
lyncoors's Avatar
Default Re: My radiator and fan, pics inside
have you tried using it as a pusher
Old Mar 25, 2010 | 07:55 AM
R.A.T.'s Avatar
Didn`t think of that one... If I go that route, all I have to do is reverse my wiring?
Old Mar 25, 2010 | 07:57 AM
00si2's Avatar
That is correct
Old Mar 25, 2010 | 08:00 AM
kyden's Avatar
might have to flip the blade around too.
Old Mar 25, 2010 | 08:01 AM
LS AzZkIkr's Avatar
What size is the fan?
Old Mar 25, 2010 | 08:07 AM
R.A.T.'s Avatar
Its either a 12" or 13"
Old Mar 25, 2010 | 08:09 AM
lyncoors's Avatar
i run 2 12inch pushers. not wired up yet. do you change the blade around or reverse the wiring?
Old Mar 25, 2010 | 08:34 AM
R.A.T.'s Avatar
Old Mar 25, 2010 | 10:11 AM
NonovUrbizniz's Avatar
Loved
If you buy a pusher fan then it's already wired to rotate the correct direction... if you reverse wire a puller it will push but not as well as a designed pusher as the fan blades are not optimized. but it works...
Also pusher fans are not as affective or efficient... but they will probobly work fine.
Old Mar 25, 2010 | 01:26 PM
lyncoors's Avatar
it will be fine, the fans hardly on anyway
Old Mar 25, 2010 | 02:25 PM
welfarepc's Avatar
i had to flip the blade and reverse the wiring when i converted my puller to a pusher. it was simple and took all of 5 minutes.
Old Mar 25, 2010 | 02:33 PM
lyncoors's Avatar
idk why but it confuses me lol
Old Mar 25, 2010 | 02:37 PM
Bailhatch's Avatar
If you can pull the fan back 1/4 to 1/2" it would work fine with a properly made shroud. That would be much better than a pusher setup.
Mine is right at the edge of my radiator but the same idea would apply, just fill in where you were going to put the plastic.
Old Mar 25, 2010 | 11:19 PM
lyncoors's Avatar
jeez what turbo set up is that
Old Mar 25, 2010 | 11:58 PM
russlan44's Avatar
why cant u mount it on the other side and reverse polarities to push or pull and thats solves ur problem and i know it will fit cuz i have it that way
Old Mar 26, 2010 | 10:06 AM
Jaker's Avatar
You do not need to flip the blades. Period.
Old Mar 26, 2010 | 12:23 PM
Bailhatch's Avatar
That's not true. Most fan blades are designed to spin one direction so you need to flip them over if the rotation is reversed. There are a few that you don't have to though. Period
Hex213
10
Feb 16, 2013 02:20 PM
f22a1 ftw
Aug 7, 2010 04:57 PM
kyle h.
Welding / Fabrication
Jun 22, 2005 07:18 PM
