92 accord h22a no spark
Old Mar 24, 2010 | 11:32 PM
more3688's Avatar
Default 92 accord h22a no spark
so my accord currently has a h22a motor in it and has a external coil, the dizzy i got is a internal coil.....I already know about crossing the wires at the coil, but it ran without doing that as long as i left the old external coil plugged in......Then it lost spark the other day, do u think i should cross the wires at the external coil, like i said the car ran perfect the way it was for months then lost spark.....Im thinking because the way i had a external and internal hooked up at the same time with the external capped off maybe it went bad and now isnt crossing the wires like it should?
This might be confusing the way i put it, but basically i still had the external coil pluged in with no wire running to the dizzy and never cut and spliced wires, and it ran fine that way for months
Old Mar 24, 2010 | 11:53 PM
redline870's Avatar
Default Re: 92 accord h22a no spark
just to get some more backround and info, why did you have the external coil plugged in at all then?
Old Mar 24, 2010 | 11:57 PM
more3688's Avatar
just cause it ran like that so i figured y mess with it at all....
Old Mar 24, 2010 | 11:59 PM
more3688's Avatar
basically with the external coil plugged in it crosses the wires for you so why cut the harness and cross them? i was gonna get a dizzy that ran off a external coil thats why i didnt wanna cut them....Just short on cash right now to buy a new dizzy
Old Mar 25, 2010 | 12:11 AM
redline870's Avatar
what do you mean cross the wires?, why would you want to cross the wires?
Old Mar 25, 2010 | 12:17 AM
more3688's Avatar
to switch it from external coil to internal coil.....
Old Mar 25, 2010 | 06:10 AM
ilikehonda's Avatar
you need to switch your external coil to an internal coil distributor. there is a write up on how to do so in the FAQ.
Old Mar 25, 2010 | 06:11 AM
ilikehonda's Avatar
you dont need to buy a new dizzy. follow the faq. if you need a distributor cap you can use one off of a 98 civic sohc vtec
SCRUBBAGE2
Apr 17, 2011 11:12 AM
philafelman
Aug 1, 2009 07:07 PM
samion33s
Sep 27, 2005 03:58 PM
type-t
Aug 19, 2004 06:40 PM
WNYAccordLX
Mar 22, 2003 06:12 AM
