Rough Idle
Old Sep 9, 2002 | 08:17 AM
2000_Civic_Si's Avatar
Default Rough Idle
MY 95 Civic Ex has a rough idle. sometime the car willalmost cut off, sometimes it idles at 1200rpm. ive recently did a tune up wires plugs cap rotor fuel filter, pcv vavle , no aftermarket. does anyone know what it might be?
Old Sep 9, 2002 | 10:13 AM
F.U.'s Avatar
Default Re: Rough Idle (2000_Civic_Si)
it s idling low or high?....if low let the car warm up then adjust the title it is a little screw on the passenger side of the throttle body try that too high check to see if your throttle cable is sticking
Old Sep 9, 2002 | 10:18 AM
turboman's Avatar
Try cleaning the idle motor on the back of the intake. I have to clean mine this weekend and hopefully it will stop my car from idling rough.
The local shop said to take it clean it with brake cleaner.
Old Sep 9, 2002 | 11:27 AM
Frosty_spl's Avatar
Default Re: Rough Idle (turboman)
There should be a little screw on the throttle body that pushes on the throttle plate. Turn the screw up to make it idle higher.
smurf357
Dec 2, 2012 11:33 AM
richi86
Mar 29, 2011 04:31 PM
BB1 H22A LUDE
Feb 25, 2008 01:55 PM
924doorEG
Nov 19, 2007 08:15 AM
oi-punx
Nov 14, 2002 02:01 PM
