wont idle lower than 1700?
i have an ls/vtec engine with stock gsr i/m and d15 throttle body that i just swapped into a 94 coupe. i had a few check engine lights but read the codes and got them all straight. now when i start the car it idles up to 2000rpm til warm then drops to 1700rpm. i turned the idle screw in all the way and nothin changed. if you tap the gas n left off it drops to about 1000rpm then picks right back up immediately. with no cel n no vacuum hoses loose im lost, any ideas?
Check for leaks in the intake system. An easy way is to spray some brake cleaner around the TB gasket and the manifold gasket. If any gets drawn in, you will hear the engine change rpms.
if that doesn't work, clean the IAC and the fast idle valve.
i cleaned the t/b before putting it on and i used gasket sealer on it because i didnt have the gasket but i have done this before with no problems. and it was a brand new honda i/m gasket but i will check for leaks 2moro. anything else? o n i cleaned the iac before installing because that was one of the cel
does the d15 throttle body even have a fast idle valve? n throttle cable is not too tight its not pulling on the throttle at all while idleing
If all that checks out, block off the idle port before the throttle blade. If your idle comes down, you have found your air leak! (The IAC may be leaking internally)
Also you could hold up th throttle body to light and see if there is excessive leakage past the blade (can be a problem with cheap aftermarket throttle bodies)
Air has to be getting in from somewhere.
anyone have a vacuum line diagram or a pic of lsvtec b18/gsr so i can make sure i have them right? i also have the vacuum line to the bottom of the iab solenoid "t"'d in with the vacuum line to the fuel ressure regulator think thaat is the problem?
pyro problem you were right it was leaking through the iac valve i just plugged off the hole until i can get a new one. still idles around 1000rpm but much better than 2200!
If at all possible, get rid of that D15 throttle body as soon as possible...it will be a restriction to the motor. Go for at least a 2nd gen B16A TB/B18B TB...they're both 60mm, which is larger than the D15.
95dc2teg
Sep 11, 2007 05:49 PM
rice a roni
Mar 15, 2007 09:47 AM
