Way too loud
Hey all,
I currently have a 3' thermal exhaust with a test pipe and a type R header on my all motor b16. Before anyone starts in on the too big/no backpressure conversation let me just say that this is not what this post is directed at, and I made significantly more power upgrading from 2.25' to 3'. With that said, over the past few weeks the exhaust has become increasingly loud. Loud enough to warrant a ticket almost every time I drive it (3 tickets in the last month). It sounds like i'm running an open header at the moment.
I checked underneath the car to determine if there was an exhaust leak. I wasn't able to find anything. A buddy of mine mentioned that perhaps the muffler has broken in a bit (I've had it for roughly 8 months now).
Does anyone know any way I can quiet it down. I brought it to a muffler shop to see if they could install a cat. They were having trouble with the fact that the type R header has a 2.5 inch collector and the thermal has 3 inch exhaust flange. First, will installing a cat significantly quiet down my system, and two where can I find a good cat that will work with my setup?
Additionally, has anyone experimented with creating a silencer for the thermal or any other unit? A friend of mine and myself considered this as well.
Finally, does anyone know any quick or band-aid fixes I can use for the time being? This is a daily driver and I have been hitching rides with my roommates and its becoming a pain in theirs and my ***.
Thanks a bunch,
Steve
Thanks a bunch,
Steve
The EF system does have a pretty decent size resonator that sits underneath the cargo area right by the gas tank. Combined with a cat maybe it will quiet it down a lot. Any idea where to get a cat that will convert from 2.5 to 3 inch?
There isn't any secret to quieting down an exhaust.
Either:
A) Get a bigger muffler, maybe a Mugen Twin-loop design or some type of Oval.
B) 20" Resonator or larger
C) A combination of A & B
There's no "Band-Aid" fix. You're not leaking any exhaust, you just have a loud-*** exhaust system.
If you add a Cat, you're going to start to cap off any performance gain your 3" SS exhaust system is giving you.
Or live with the tickets and have a stock exhaust you can put on for the "fix-it ticket" dates.
Either:
That part under the gas tank is the muffler. A resonator will usually be in the B pipe.
You can always order a 3" cat, and just get a reducer. They are a little pricey though:
http://www.burnsstainless.com/rd-250-350-18-304-s.aspx
http://www.sfxperformance.com/parts/VIB1142.htm
I figure maybe one or two of these could significantly quiet it down. Or do a combination of the cat and the resonator
+Resonator & cat, you can cut the outlet on the cat and get a taperd peice of SS from 2.5in to 3in and weld your exhuast to the cat. or custom cat from smsp like someone said
A good resonator will make a significant difference. You can install it pretty much anywhere along the exhaust from behind the collector to in front of the muffler. Welding it in is not hard and any exhaust shop should be able to do it. I popped one in yesterday in about 30 min from the car rolling up to my house to it driving off.
Jeff92NY
14
Oct 29, 2003 12:09 PM
