sensor error
Just a question I have to ask I have a problem with obd1 code 43 (knock sensor error) on a non-vtec '93 honda civic it knocks every now and then when i crank it up but the check engine light comes on after I've been driving for about 10 minutes whether it's running fine or shitty I know the head gasket is shot it leaks slowly onto my transmission but I can deal with that for now I was thinking maybe the injectors could be to blame since it has over 213,000 miles on it the engine is all stock and the fuel pump is about 6-8 months new I just changed the plugs and wires any suggestions?
it's the obd1 1.5l sohc engine I don't know the exact name of it but its the dx I can locate the knock sensor on the back of the head I just took some pictures of the engine I will upload them shortly
That's definitely a stock '92-'95 DX/LX engine (D15B7). You can see the engine code on the sticker on the timing belt cover. It's also imprinted on a flat plate on the engine block, on the front, where the engine meets the transmission.
But with that engine, you shouldn't have a knock sensor. If you're throwing that code, I'm guessing that you have the wrong ECU. It should be a P06. If you pull back the carpet under the passenger side of the dash, it will be bolted to the right side. On the ECU, once you unbolt it from the side there, will have a sticker on it with the ECU code. It will say something like 37820-P06-A01; with the P06 being important ECU identification code you're looking for.
Mike ogden
Jan 22, 2018 02:41 PM
redlines4us
Jun 29, 2009 04:26 AM
diilbert
Honda Civic (2001 - 2005)
Sep 6, 2007 08:49 PM
