Just bought a 95 4 door for $500 but it has many problems help!
Old Mar 24, 2010 | 11:13 AM
fourdoorteg's Avatar
Default Just bought a 95 4 door for $500 but it has many problems help!
The car has 17's on it and that is merely for the fact that whoever the dumb asses that owned the car before could not get the wheel locks off(rusted and stripped). Apparently, this idiot tried to use a blowtorch to something? on the front right wheel. So first off, How do i get these lugs off?
secondly, it has no brakes PERIOD no e-brake or anything. There is no pressure on the pedal and the kid said there was a leak in one of the lines. One of his friends said that all the lines needed to be replaced(rusted out?) So how do i check the lines and so forth. ill get pictures up later thanks
Old Mar 25, 2010 | 07:52 AM
Default Re: Just bought a 95 4 door for $500 but it has many problems help!
so it turns out the hard brake lines are rusted. anyone know how to swap out the lines easily? should i go to the junk yard and find some lines or just bend my own? please help
Old Mar 25, 2010 | 08:47 AM
98integralsB18's Avatar
get some old sockets weld the socket on the lug and put a ratchet on it and ta daa! Break lines like make some pre bent like the front ones im not sure about the rears or anything but i'd bend my own its not to bad.
Old Mar 25, 2010 | 10:10 AM
95 integra's Avatar
You can try a bolt-out or something like that....or drill the studs from the backside.
JDM.Type-r
Jan 24, 2008 01:35 PM
94sicoupe
Oct 12, 2007 09:47 PM
FastHatch90
May 11, 2006 08:07 PM
adam94lude
Oct 20, 2005 01:38 PM
extro97
Apr 13, 2005 08:35 AM
