HELP with changing brake lines
Old Oct 10, 2007 | 02:23 PM
94sicoupe's Avatar
Default HELP with changing brake lines
bought a 94 teg.. brakes lines are leaking like crazy so i want to change all of them.. its leaking from rite underneath the body where the door is...
how do i take them off need some help i was looking for a diy could not find one..
thanks for taking a look and 4 ur feedback in advance.. hopefully it will be back on the road pretty soon
Old Oct 10, 2007 | 02:44 PM
St Jimmy's Avatar
* B A N N E D *
Default Re: HELP with changing brake lines (94sicoupe)
Could it be your abs lines the o rings tend to leak, check this out.
https://honda-tech.com/zerothread?id=1451186
Old Oct 10, 2007 | 02:49 PM
Duane_in_Japan's Avatar
Many years ago in Ohio I had to replace all the brake lines on a ladies car, they were all rusted out, I had to pull them and create all new ones from straight stock line, I had to bend them all by hand to get them to mount up in the stock clips, not fun, several couplers were used for the long run sections too. Start disassembling my friend.
Do one wheel at a time and bleed it as you go.
Old Oct 11, 2007 | 02:09 AM
94sicoupe's Avatar
does any one have pics??.. like from a haynes manual or somethin .. i know i had one but cant find it now..
Old Oct 11, 2007 | 02:04 PM
94sicoupe's Avatar
bumpp
94sicoupe's Avatar
Modified by 94sicoupe at 6:47 AM 10/13/2007
Old Oct 12, 2007 | 09:47 PM
94sicoupe's Avatar
FIBAH
Feb 25, 2017 05:53 PM
Nickb257
May 4, 2010 01:44 AM
FastHatch90
May 11, 2006 08:07 PM
MR-MUGEN
Welding / Fabrication
Sep 19, 2005 06:14 PM
gezer
Oct 12, 2004 11:18 AM
