***Built D16z6 Turbo question***
Old Mar 24, 2010 | 08:37 AM
Dual Cam Killer's Avatar
Default ***Built D16z6 Turbo question***
Ok just got my car runnin here a few days ago, only mods to the engine that arent factory replacement are Eagle H beam rods, vitara pistons std bore, Golden Eagle block guard and Arp Head studs.
The Question
I just hooked up a mechanical oil pressure gauge yesterday, and at a 850rpm idle, the gauge reads between 5psi and 10psi. Is that correct?
Really apreciate any help that I can get. Thanks again fellas.
Old Mar 24, 2010 | 09:07 AM
shifty35's Avatar
Default Re: ***Built D16z6 Turbo question***
Seems a hair low for a warm idle. What are your oil clearances, and what oil are you using?
Old Mar 24, 2010 | 11:36 AM
Psychoteen101's Avatar
That sounds dangerously low. What does the oil pressure look like at a 3,000rpm rev?
Old Mar 24, 2010 | 03:47 PM
when im runnin down the road at 45mph in 5th gear, its readin at 40psi. god I hope my ***** not phucked up lol tired of foolin with this thing lol
Old Mar 24, 2010 | 03:48 PM
oh and Im using 10w-30 oil and not sure bout my oil clearances. The engine is fresh, only 225 miles on her rite now.
Old Mar 24, 2010 | 04:17 PM
kandstd16t's Avatar
hey quick question what is your compression when you run those pistons did you get any info
Old Mar 24, 2010 | 04:44 PM
md_d16y8's Avatar
you should have at the least shimmed your oil pump...better yet...open up those ports on the pump
Old Mar 24, 2010 | 07:11 PM
shifty35's Avatar
You may want to step up to a 40 weight oil if you don't have sufficient pressure at higher RPMs.
Old Mar 24, 2010 | 07:24 PM
^^ Thats not fixing anything, thats just attempting to cover up the problem.
40psi is not very good under throttle. I had a motor with pretty much the same pressure and it didnt last 5,000 miles. Did you replace the bearings? If you did, then did you check the clearances?
If i were you, id take it back apart.
Old Mar 26, 2010 | 02:21 PM
md_d16y8's Avatar
I know that before I did any work to the oil pump(which happened to be in between builds), on a hot *** day running 10w30 @ idle it would be around 11-15 psi, now i get around 20-25'ish. 60 psi @3k
Old Mar 26, 2010 | 09:08 PM
stiffdogg06's Avatar
Look in your Honda manual.
10psi at idle
50psi at 3,000rpms
These are at operating temp.
And regards to who ever said dont run 40weight oil... If you have loose bearing clearances (like me) you may need to run a little thicker oil...
Also, 10psi per 1,000rpm and you'll be fine. Flow > Pressure.
Old Apr 2, 2010 | 06:30 AM
ok so should i run 10w-40, or 20w-50?
Old Apr 2, 2010 | 07:38 PM
iamthefollower's Avatar
Man, I would probably just run the 10w-40 Matt. You need to shorten up your oil feed line too. I can't wait for that thing to be the way you want it so you can quit worrying soooo much on it. .. Going to have mine done soon to roll out with you all for Varsity or wtf ever lol..
Old Apr 4, 2010 | 01:08 PM
Run the 10W40. 20W50 is like molasses on start up... I see NO benefits from running that thick of an oil in our motors.
Hell, if you can get it, run 5W40. It's all about experimentation. 40 might be too thick for you. You may need to run 5W30 or something... 10psi per 1,000rpms.
EG6 Love
Mar 23, 2010 04:16 PM
boostedteg1203
Jan 27, 2010 01:50 PM
Elevorett
10
Jan 2, 2010 06:23 PM
TurboCX
Aug 3, 2003 06:33 PM
